Linking Production Items to KDS Displays
  1. Select the property, click Setup, and then click KDS Displays.
  2. Double-click a KDS Display record to open it.
  3. Click the Production Item tab.
  4. From the KDS Production Location drop-down list, select where to place the production bar on the display.
    • To set the production bar to appear above the order chit, select 1 - Top.
    • To set the production bar to appear below the order chit and above the KDS toolbar (if used), select 2 - Bottom.
  5. From the KDS Production Columns drop-down list, select the number of production items to show per line or production bar. When possible, the KDS displays the maximum number of items in each bar. If there are not enough items to fill the last bar, the remaining items are evenly distributed across the line.
  6. From the Production Items section, click Add, select a production item to appear on the KDS, and then select its Persistence:
    • Static: Select to always show the production item on the KDS Display.
    • Dynamic: Select to show the production item on the KDS Display only when it has an item count.
  7. Repeat Step 6 until all of the production items to display on the KDS appear in the list.
  8. Click Save.
