Configuring the Event Buttons
To allow workstation operators to manually start and end an event, you need to add buttons assigned to the touchscreen page.
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Open the page on which to place the Start Event and End Event buttons.
- On the Edit tab, select the page area in which to define the Start Event button.
- Click Button.
- On the General subtab, enter the button name (for example, Start Event) in the Legend field.
- Select Function from the Type drop-down list.
- Click the black arrow directly beneath the Type drop-down list, select the type Event Management, select the results Start Event, and then click OK.
- Position and size the button on the page. Use the Style arrow to change the color.
- Repeat Steps 3 through 9 to create the End Event button, selecting End Event for the result.
- Click Save.
Related Topics
- Configuring Event Privileges and Permissions
- Specifying Ad Hoc Reports
- Enabling Events
- Configuring Event Types and Sub Types
- Creating an Event
- Configuring an Event Area
- Linking Events
- Breaking Linked Events
- Cancelling an Event
- Configuring Event Information to Print on Checks and Receipts
- Creating Task Schedules
- Configuring the Event Status Bar
- Event Information in Reporting and Analytics Reports
Parent topic: Events
