Configuring Event Privileges and Permissions
You can assign event privileges to employees.
  1. Select the Enterprise level, click Configuration, and then click Roles.
  2. Double-click the role type, and click the EMC Modules tab.
  3. For each of the following event-related items listed in the File column, select the appropriate employee privileges (View, Edit, Add, and Delete):
    • Event Types: This file controls the ability to view, change, create, and delete event types and sub types.
    • Event Areas: This file controls the ability to view, change, create, and delete event areas.
    • Event Definitions: This file controls the ability to view, change, create, and delete events.
    Setting Employee Roles contains more information about setting employee privileges.
  4. To set field level permissions, click the Fields tab.
  5. Select Event Definitions from the EMC Modules list.
  6. For Areas and Cancel Event, select the appropriate permissions from the Access drop-down list.
  7. To set event check privileges, click the Operations tab, and then click the Transactions subtab.
  8. Select the appropriate options for the privileges. The following table summarizes the check privileges associated with event functionality and the recommended roles to have the privilege set.
    Table 50-1 Event Check Privileges
    Option Number Privilege Name Allow the Employee to Authorize or Perform ... Recommended Roles
    270
    Authorize/Perform association of a new check to an ended event
    Creating a new check and linking it to a closed or ended event
    Manager
    271
    Authorize/Perform override of the "Event association to a Check is mandatory" option (Control Parameters)
    Beginning a check without linking it to an event
    Manager
  9. Click the Miscellaneous subtab.
  10. Select the appropriate options for the privileges. The following table summarizes the workstation privileges associated with event functionality and the recommended roles to have the privilege set.
    Table 50-2 Event Privileges
    272
    Authorize/Perform Start an Event
    Starting an event
    Manager
    273
    Authorize/Perform End an Event
    Ending an event
    Manager
    276
    Authorize/Perform Select an Event
    Selecting an active event as the workstation operator’s default event
    Manager
    277
    Allow selection of ‘No Default Area Selected’ when assigning default event
    Selecting a default event without selecting a default area.
    Manager
  11. Click Save.
