11 Employees and Privileges
If you are using Oracle Hospitality Labor Management, you need to add employees using Labor Management. The Oracle Hospitality Labor Management Cloud Service Feature Reference Manual, located at the Oracle Help Center, contains information about adding employees in Labor Management. The initial employee information is sent from Labor Management to Simphony. To change the role for an existing employee, use the Simphony EMC.
In Simphony, privileges determine the activities an employee can perform, the EMC modules available to the employee, and the types of transactions the employee can process. You can configure privileges by the job role (for example, host, server, bartender, cashier, manager).
- Creating Employee Roles
- Menu Item Field Security
- Creating Employee Classes
- Allowing Users to Override Employee Class Options
- Adding an Employee
- Deleting an Employee
- Changing Employee Information
- Configuring Employee Shifts
- Configuring Employee Breaks
- Configuring Time Card Chit Printing
- Clock-In and Clock-Out Cycles
- Setting Clock-In and Clock-Out Cycles
- Declaring Tips
- Configuring Tip Tracking and Reporting
- Configuring Tip Track Buttons
