Allowing Users to Override Employee Class Options
You can optionally override Employee Class configuration options for individual workstation operators.
  1. Select the Enterprise, zone, property, or revenue center, click Configuration, and then click Employee Maintenance.
  2. Select a property and revenue center, and then click Search.
  3. Select Operator Records.
  4. Select Override Class Options for an employee.
  5. Select the override options.
    Table 11-3 Override Employee Class Options
    Option Description
    Options
    When you select Override Class Options, the application automatically selects the Operator Options for the employee’s revenue center. You can override option 25 - View Blind Totals here.
    Cash Management Accounting Method
    When you select a Cash Management accounting method here for an employee, you override the accounting method set in the Employee Class module.
    Cash Drawer
    This option indicates the cash drawer that is defined for the workstation operator within the revenue center: 0 (no cash drawer assignment, user prompted), 1, or 2. The Quick Start till operation uses the defined cash drawer.
  6. Click Save.
