Configuring ECM Privileges and Permissions
- Select the Enterprise level, click Configuration, and then click Roles.
- Select the role type (for example, administrator, manager or server), and then click the EMC Modules tab.
- In the Cash Management section, select the appropriate
Cash Management operation permissions for the user role. You can grant
permissions for the following actions:-
                                 View: Open and view a Cash Management module. If you allow a user to Edit, Add, or Delete, you must also grant View access (otherwise the user cannot open the module).
                                 Edit: Update fields or records within a module.
                                 Add: Add records to a module. You cannot add records to the Cash Management Class Behavior module.
                                 Delete: Delete records from a module. You cannot delete records from the Cash Management Class Behavior module.
                                 Add Override: Override records in a module. You cannot override records in the Cash Management Classes module.
- Click the Operations tab, and then click the Cash Management subtab.
- Select the appropriate options for the privileges. The
following table summarizes the privileges associated with ECM functionality
and the recommended roles to have the privilege set.Table 53-1 ECM Privileges Section Option Number Privilege Name Allow the Employee to Perform or Authorize... Recommended Role(s) General Operations 249 Change Count Sheet Changing the count sheet that the receptacle session uses Manager General Operations 250 Pull Cash A cash pull Cashier, Manager General Operations 258 Threshold Level Exception A Cash Pull Threshold Exception (bypass the threshold notification) when prompted and permitted Manager General Operations 260 View Receptacle Session Status Viewing of summary information for all active receptacle sessions Manager General Operations 267 Update Balance on Count Updating the balance on a count when the amount is outside the count threshold values Manager General Operations 301 View Cash Management Dashboard Viewing the Cash Management Dashboard page Manager General Operations 302 View Cash Management Dashboard Detail Viewing the till and server bank detail from the Cash Management Dashboard page Manager Till Operations 201 Assign Till to Cash Drawer Assignment of a till to a cash drawer on a workstation Manager Till Operations 202 Unassign Till from Cash Drawer Unassignment of a till to a cash drawer on a workstation Manager Till Operations 203 Assign User to Till Perform or authorize the assignment of an employee to an active till session Manager Till Operations 204 Unassign User from Till Unassignment of an employee to an active till session Manager Till Operations 205 Count Till Counting of a till session Cash Handler Till Operations 206 Adjust Till Count Adjustment of the last count for a till session Manager Till Operations 207 Paid-In/Paid-Out Posting of an ECM paid-in or paid-out on a till session Workstation operators can perform standard paid-in and paid-out transactions based on Tender/Media configuration. Manager Till Operations 209 Transfer Funds Transfer of items from a till session to another cash receptacle session Cashier, Manager Till Operations 210 Deposit Funds Deposit of cash from a till session to a bank deposit session Cash Handler Till Operations 212 Close Till Closing of a till session Cash Handler Till Operations 213 Reopen Till Reopening of a till session Manager Till Operations 251 Quick Start Till Opening of a till session and assignment of the current operator to a workstation cash drawer Cash Handler Till Operations 259 Adjust Till Starting Amount Adjustment of the till starting amount Manager Server Bank Operations 241 Start Server Bank Opening of a new server bank session Manager Server Bank Operations 242 Count Server Bank Counting of a server bank session Manager Server Bank Operations 243 Adjust Server Bank Count Adjustment of the last count for a server bank session Manager Server Bank Operations 244 Paid-In/Paid-Out Posting of an ECM paid-in or paid-out on a server bank session Workstation operators can perform standard paid-in and paid-out transactions based on Tender/Media configuration. Manager Server Bank Operations 245 Transfer Funds Transferring of funds from a server bank session to another cash receptacle session Manager Server Bank Operations 246 Deposit Funds Deposit of cash from a server bank session to a bank deposit session Manager Server Bank Operations 247 Close Server Bank Closing of a server bank session Manager Server Bank Operations 248 Reopen Server Bank Reopening a closed server bank Manager Server Bank Operations 265 Adjust Server Bank Starting Amount Adjustment of the server bank session starting amount Manager Server Bank Operations 269 Consolidate Server Banks Consolidating two server bank sessions Manager Safe Operations 214 Open Safe Opening of a new safe session Manager Safe Operations 215 Count Safe Counting of a safe session Manager Safe Operations 216 Adjust Safe Count Adjustment of the last count for a safe session Manager Safe Operations 217 Paid-In/Paid-Out Posting of an ECM paid-in or paid-out on a safe session Workstation operators can perform standard paid-in and paid-out transactions based on Tender/Media configuration. Manager Safe Operations 218 Transfer Funds Transferring of funds from a safe session to another cash receptacle session Manager Safe Operations 219 Deposit Funds Deposit of cash from a safe session to a bank deposit session Manager Safe Operations 220 Close Safe Closing of a safe session Manager Safe Operations 261 Add Funds to Safe Adding new funds into ECM through a safe receptacle Manager Safe Operations 262 Remove Funds from Safe Removing funds from ECM through a safe receptacle Manager Petty Cash Operations 222 Open Petty Cash Opening of a new petty cash session Manager Petty Cash Operations 223 Count Petty Cash Counting of a petty cash session Manager Petty Cash Operations 224 Adjust Petty Cash Count Adjustment of the last petty cash session count Manager Petty Cash Operations 225 Paid-In/Paid-Out Posting of an ECM paid-in or paid-out on a petty cash session Workstation operators can perform standard paid-in and paid-out transactions based on Tender/Media configuration. Manager Petty Cash Operations 226 Transfer Funds Transferring of funds from a petty cash session to another cash receptacle session Manager Petty Cash Operations 227 Deposit Funds Deposit of cash from a petty cash session to a bank deposit session Manager Petty Cash Operations 228 Close Petty Cash Closing of a petty cash session Manager Bank Deposit Operations 233 Create a Bank Deposit Opening of a new bank deposit session Manager Bank Deposit Operations 234 Transfer Funds Transferring of funds from a bank deposit to another cash receptacle session Manager Bank Deposit Operations 237 Adjust Cash Deposit Adjustment of a cash deposit amount in a bank deposit session Manager Bank Deposit Operations 239 Reconcile Bank Deposit Reconciliation of a bank deposit session Manager Bank Deposit Operations 264 Adjust Bank Deposit Reference Adjustment of a reference on a bank deposit session Manager Change Order Operations 230 Create Change Order Creation of a new Change Order request from a safe session Manager Change Order Operations 232 Reconcile Change Order Reconciliation of a Change Order Manager Change Order Operations 252 Submit Change Order Submission of a new Change Order request from a safe session Manager Change Order Operations 268 Save / Recall Change Order Saving or recalling a Change Order Manager
- Click Save.
Related Topics
- Configuring Data Retention Limits
- Allowing Users to View Blind Totals
- Allowing Assigned Receptacle Access and Counts
- Configuring Accounting Methods for Users
- Allowing Users to Override Employee Class Options
- Creating, Editing, and Deleting Cash Management Reasons
- ECM Workstation Hardware
- ECM Configuration Levels
Parent topic: Enterprise Cash Management
