Configuring Accounting Methods for Users
You can specify the type of accounting method a workstation operator uses to track cash management activities. The method you select determines the type of Front of House receptacles the workstation operator can access.
Related Topics
- Configuring Data Retention Limits
- Configuring ECM Privileges and Permissions
- Allowing Users to View Blind Totals
- Allowing Assigned Receptacle Access and Counts
- Allowing Users to Override Employee Class Options
- Creating, Editing, and Deleting Cash Management Reasons
- ECM Workstation Hardware
- ECM Configuration Levels
Parent topic: Enterprise Cash Management
