Allowing Users to View Blind Totals
In some cases, you can require that workstation operators view the difference between the amount entered during a count and the amount expected by application transaction activity. Selecting View Blind Totals allows workstation operators within the Employee Class to view application expected values and the difference on the count sheet. When an over or short condition exists, the workstation operator can select the reason for the variance.
- Select the property, click Configuration, and then click Employee Classes.
- Select the role type, and then click Operator Options.
- Select 25 - View Blind Totals.
- Click Save.
Related Topics
- Configuring Data Retention Limits
- Configuring ECM Privileges and Permissions
- Allowing Assigned Receptacle Access and Counts
- Configuring Accounting Methods for Users
- Allowing Users to Override Employee Class Options
- Creating, Editing, and Deleting Cash Management Reasons
- ECM Workstation Hardware
- ECM Configuration Levels
Parent topic: Enterprise Cash Management
