Enterprise
Use Enterprise-level configuration for records and settings that apply across the Simphony Enterprise. Enterprise-level records can provide a common baseline for properties and revenue centers, reducing duplicate configuration while allowing lower levels to override values when needed.
Examples of configuration that is commonly managed at the Enterprise level include:
Module availability varies by hierarchy level. Confirm the available levels for the module and record type before creating a record.
Inheritance and overrides
For modules that support inheritance, values defined at the Enterprise level are inherited by lower levels. Define shared configuration at the Enterprise level, and create an override only when a property, revenue center, or zone requires a different value. See Inheritance and Overrides for details.
