In this chapter Create a library Set the primary layout for a library Select the supported locales for a library Choose the default locale for a library Set up library teams Add a study object or library object to a library Categorize a study object Create predefined sets of drop-down list options, radio buttons, or checkboxes (codelist subsets) in a library Create a study object template Create an item type Mark an item as mandatory Protect a library and all its objects Unprotect a library Publish an object to make it available to copy into a study Publish, republish, or unpublish a library to make its objects available to copy into a study Disable a library |
