In this section What is a library? What is the System Library? What happens if I unprotect an object in a library that I copied to a study? What happens when I unpublish an object in a library? About publishing, republishing, and unpublishing How can I use published study objects in workflows? Results of modifying study objects that have been copied to studies and libraries What are examples of using libraries effectively? What is a template? What is a type? What is the difference between a template and a type? What information can I define for templates and types? About searching for a template or type What is an item type? What happens when I add a template to a study? |
