Viewing synchronization error details for the last job
You can view error details for the last synchronization connection job from the Status tab of the CIS Synchronizations page.
- Select Admin > CIS Sync.
- Click the row of the synchronization connection you want to view.
The Status tab of the CIS Synchronization Connection page appears.
- Click View Error next to the job in the table.
The Synchronization Connection Error Details page appears. This page provides information about when the errors occurred, the source of the error, and details about the error.
Depending on the type of error, buttons at the bottom of the page are enabled, and you can either edit transactions or specify new mapping if the synchronization connection is defined to allow intervention for stopped synchronizations. For more information, see:
