Modifying Groups of Discrepancies
With the Group Function utility, you can query for and select a group of discrepancies and simultaneously update their review status, comment text, or CRF page numbers, mark them for passive review, or create DCFs for them. To access the Group Function utility, open the Maintain Discrepancy Database window in multi-record view; from the Conduct menu, select Data Validation, then select Discrepancy Database, and then the Multi button. You can make the several types of changes, including:
The process involves the following general steps:
