Link Parameters
The following table describes all the possible parameters for static links and dynamic links. The scope of a link defines the subset of these parameters that RDC appends to your specified URL or passes to your specified function.
| Static Links Parameter Name | Dynamic Links Parameter Name | Database Object | Description |
userid |
pUserId |
USERID |
Sends the login user ID of the RDC session. |
user_role |
pUserRole |
USER_ROLE |
Sends the RDC login user's assigned role value. |
test_prod |
pTestProd |
TEST_PROD |
Sends the session's study mode: T for Test mode or P for Production mode. |
study_id |
pStudyId |
CLINICAL_STUDY_ID |
Sends the internal Oracle Clinical identifier that corresponds to the STUDY value. |
study |
pStudy |
STUDY |
Sends the session's Oracle Clinical Study name. |
site_id |
pSiteId |
SITE_ID |
Sends the internal Oracle Clinical identifier that corresponds to the SITE value. |
site |
pSite |
SITE |
Sends the session's SITE value. |
patient_id |
pPatientId |
PATIENT_POSITION_ID |
Sends the internal Oracle Clinical identifier that corresponds to the PATIENT value. |
patient |
pPatient |
PATIENT |
Sends the name of the PATIENT the user is currently viewing. |
book_id |
pBookId |
DCI_BOOK_ID |
Sends the internal identifier that corresponds to DCI_BOOKS.NAME. |
book |
pBook |
DCI_BOOKS.NAME |
Sends the name of the DCI book the user is currently viewing. |
dci_id |
pDciId |
DCI_ID |
Sends the internal Oracle Clinical identifier that corresponds to the user's currently viewed DCI. |
cpe_id |
pCpeId |
CLIN_PLAN_EVE_ID |
Sends the internal Oracle Clinical identifier that corresponds to the user's currently viewed Clinical Planned Event. |
subno |
pSubNo |
SUBEVENT_NUMBER |
Sends the subevent number. |
page_display_sn |
PPageDisplaySn |
DISPLAY_SN |
Sends the DCI's sequence number, its viewing order in the currently viewed DCI Book. DISPLAY_SN is in the DCI_BOOK_PAGES table. |
page_no |
pPageNo |
Sends the derived page number in the currently viewed Data Entry window of a multiple-page DCI. |
pHeader |
Sends the value of the URL field. This value is used in earlier RDC releases. It is available in dynamic links but not in static links. |
pScope |
Sends the scope type to a dynamic link function. It is available in dynamic links but not in static links. |
For more information, see:
Parent topic: Configuring Links
Parameters for Static Links Based on Scope
Static links generate a URL from the target HTTP address defined in the Maintain Links form. Based on the scope of the link, RDC appends a subset of parameter values from the user's current session to your specified URL when the user clicks the link.
You create a target Web page that can resolve the parameter values that RDC appends to the URL. You do not have to use all of the parameters, but the target page must be able to open the URL.
The following table lists the parameter strings that RDC appends to static links, according to the scope of the link.
| Scope | Parameter String Appended to the URL Value |
None |
RDC appends no parameters to the URL value. |
User |
Study |
Site |
Patient |
CRF |
Parent topic: Link Parameters
Parameters for Dynamic Links Based on Scope
Dynamic links derive an HTTP address from a function. You create a function that returns a URL.
The following table lists the parameters that RDC passes to a SQL function, according to the scope of the link. All parameters are VARCHAR2 except for the pStudyId and pSiteId parameters, which are NUMBER.
| Scope | Parameters Passed to the SQL Function |
None |
User |
Study |
Site |
Patient |
CRF |
The Maintain Links form does not verify the existence of, validity of, or access privileges to functions or data.For more information, see:
Sample Function Available
Oracle provides the following sample function that you can use when defining links:
dmo_links.geturl
This function is in the rxcpbdmolinks.sql file, which is located in the INSTALL directory.
Parent topic: Parameters for Dynamic Links Based on Scope
Function Specification for Dynamic Links
The following specification outlines the requirements of the function that is accessed by dynamic links with a scope of CRF.
A dynamic link with a scope of CRF processes all available session parameters. You can specify functions for dynamic links of other scopes with fewer parameters, but if you use DEFAULT NULL then you can include the extra parameters.Create or replace FUNCTIONsub-program name here( , pHeader IN VARCHAR2 DEFAULT NULL , pScope IN VARCHAR2 DEFAULT NULL , pUserId IN VARCHAR2 DEFAULT NULL , pUserRole IN VARCHAR2 DEFAULT NULL , pTestProd IN VARCHAR2 DEFAULT NULL , pStudyId IN VARCHAR2 DEFAULT NULL , pStudy IN VARCHAR2 DEFAULT NULL , pSiteId IN VARCHAR2 DEFAULT NULL , pSite IN VARCHAR2 DEFAULT NULL , pPatientId IN VARCHAR2 DEFAULT NULL , pPatient IN VARCHAR2 DEFAULT NULL , pBookId IN VARCHAR2 DEFAULT NULL , pBook IN VARCHAR2 DEFAULT NULL , pDciId IN VARCHAR2 DEFAULT NULL , pCpeId IN VARCHAR2 DEFAULT NULL , pSubNo IN VARCHAR2 DEFAULT NULL , PPageDisplaySn IN VARCHAR2 DEFAULT NULL , pPageNo IN VARCHAR2 DEFAULT NULL )RETURN VARCHAR2 IS BEGINsub-program logic hereEND;
