Review data load errors (optional)
To review data load errors:
- Click Study Manager in the navigation bar and select a
study from the Studies panel.
For details on selecting a study, see Select a study from the Home page. - Click the Data Loads tab to open a table with details on files that loaded into the selected study.
Open a file in one of the following columns:
Last Load Results: Contains the results of the most recent data load. This file is produced whether the data load is successful or failed.
View Output:: Produced during a data load (the SQL*Loader log). This file is produced whether the data load is successful or failed.
View Error File: Created when a text file for a data load contains more fields than there are columns in the table you're loading the data into. This file is produced for failed data loads only.
Tip:
This column is typically empty.
View Comprehensive Error Report: The error log includes a list of the specific data record and field from the file that caused the error. This file is produced for failed data loads only.
Parent topic: Check if data files loaded
