Manage Signal Configurations page
On the Manage Signal Configurations page, you can modify, delete, and publish the signal configurations. You must have the Manage Signal Configurations permission or be a superuser to access this page.
General activities
The following links appear at the top of the page and affect the entire page:
Row-specific activities
The following options appear in the Row Action menu () for each signal configuration:
- Edit
- Publish
- Edit Comment Types
- Edit Product fields
- Edit Alert Types
- Edit Product Columns
- Edit Product-Event Combinations Columns
For interactive signal configurations only:
Field descriptions—Manage Signal Configurations page
Field | Description |
Name |
Signal configuration name. When more than one signal configuration is published to a user, this name appears on the Signal Review page next to the title. |
Description |
Description of the signal configuration. |
Topic Workflow Configuration |
Name of the topic workflow configuration that is integrated with the signal management configuration. When this integration exists, users can associate topics with product-event combinations using the Submit Review dialog box, and topics are stored in this topic workflow configuration. Note: If product-event combinations have associated topics, you cannot change the associated topic workflow configuration until you remove the associated topics. The Signal History maintains a log of all changes. |
Topic Product Field |
Topic field in which product names from product-event combinations associated with topics are stored. You can also use the Topic filter when browsing for existing topics from the Submit Review dialog box. |
Modified By |
Role or name of the user who modified the configuration. |
Modified |
Date and time when the configuration was modified. |
Type |
Type of signal configuration. The value can be Scripted or Interactive. For more information, see About signal configurations. |
Created |
Date and time when the configuration was created. |
Created By |
Role or name of the user who created the configuration. |
ID |
Identifier assigned automatically to the configuration when the configuration was created. Each configuration ID is unique and is not re-used if the configuration is deleted. |
Current Period |
Period used in last successful refresh; null if scripted. |
Data Refreshed |
Date of last successful refresh. |
Parent topic: Manage signal configurations
