About signal configurations
There are three types of signal configurations: scripted and multisource.
- Scripted signal configurations require modifying most aspects of the signal configuration outside of the Oracle Empirica Signal application, based on your organization's requirements, and running command-line scripts to perform refreshes. Scripted signal configurations are available for other data sources, including proprietary databases.
- Interactive signal configurations allow a user, with appropriate
permissions, to create, validate, and refresh the configuration in the Oracle Empirica Signal application.
Interactive signal configurations are currently available for proprietary data maintained in Oracle Argus Mart and for various public safety data sources. See What is source data?.
- Multisource signal configurations extend interactive signal configurations by combining the results of multiple safety datasets, both public and proprietary, into a single configuration. You can view data and results side-by-side on the Signal Review page. With the appropriate permissions, you can select the signal configurations you wish to combine, then create and manage the multisource configuration in the Oracle Empirica Signal application.
To set up the configurations, you must have the Manage Signal Configurations permission. See Edit a signal configuration.
Most aspects of scripted signal configuration are defined or modified outside of the Oracle Empirica Signal application based on your organization's requirements. You can modify some aspects of the signal configuration.
For example, you can:
- Add and edit signal comment types.
- Enable or disable review periods.
- Edit the column headers and column descriptions on the Products table.
- Edit the column headers and column descriptions on the Product-Event Combinations tables.
- Define values for Category, Complexity, and Organization product properties.
You can modify interactive signal configurations in the Oracle Empirica Signal application. For example, you can:
- Select the data configurations used for reports and data mining runs.
- Select drug and event variables used in data mining runs as well as stratification and subset variables.
- Add, edit, activate, and deactivate alert types.
- Manually refresh the signal management data.
You can create and modify multisource signal configurations in the Oracle Empirica Signal application. See Get started with multisource signal configurations.
For example, you can add and edit multisource configurations and specify the lead and secondary configurations.
- Add a multisource signal configuration.
- Edit a multisource signal configuration
- Add and edit signal comment types, changes shared with the lead configuration.
Parent topic: Manage signal configurations
