Mapping new forms to an auto-generated CDD
When you create a new form in the InForm Architect application or load an XML file containing a form definition, the form is added to the list of forms in the Trial Objects window so that you can add to or update its design. To map form controls to a manual CDD, follow the instructions in Creating a CDD mapping definition table, Creating a CDD mapping definition table column, and Mapping a form control. To map the form and its controls to an automatically generated CDD:
- Open the Form window in the Design Workspace.
- Right-click the Form RefName, and select Add to Auto-Generated Data Mappings.
The InForm Architect application generates table, table column, and control path mappings for the components of the form definition in each automatically-generated CDD and Clintrial software database in the trial.
