Identifying code targets
Code target mappings identify the controls on an InForm application form that hold data that has been coded with Central Coding. The dictionary you choose for a verbatim determines the targets you can set. For example, when using the MedDRA, 8.1, en-US dictionary, you can set the following targets for any verbatim:
- System Organ Class.CODE
- System Organ Class.TERM
- High Level Group Term.CODE
- High Level Group Term.TERM
- High Level Term.CODE
- High Level Term.TERM
- Preferred Term.CODE
- Preferred Term.TERM
- Low Level Term.CODE
- Low Level Term.TERM
You can add, update, or remove a code target mapping. To add or update a code target control mapping, use either of the following methods:
- In the Data Mappings window, specify a RefName path. For more information, see Specifying a RefName path to add or update a code target path.
- Drag the control from the Form window to the Data Mappings window. For more information, see Dragging a control to add or update a code target path.
