Defining an individual control mapping
To create a single control mapping, you can do the following:
- In the Data Mappings window, use the New Mapping pop-up menu command for the item in which you want to create the control path.
- In the Form window, use the Add Data Mapping pop-up menu command for the control you want to map, or you can drag the control from the Form window onto the Data Mappings window.
