Using the Data Mappings window to define an individual control mapping
To create a control mapping definition:
- In the Data Mappings window, right-click the Mappings node.
- From the pop-up menu, choose New Mapping.
The Build RefName dialog box appears.
- For each component of the RefName path, select the component from the list in the dialog box.
- Click Next, or, to backtrack to a previous component, click Back.
The InForm Architect application builds the path from your selections and displays it in the Path field at the top of the dialog box.
- When the RefName path is complete, click Done.
The InForm Architect application inserts the path into the component definition you are creating.
- Select the control path, and edit its mapping properties in the Properties window as described in Displaying RefName paths for all controls.
