Roadmap: Configuring corrections to subject information
This roadmap describes the typical process of configuring edits to subject information, including the approval cycle set up by the sponsor. The way these systems operate can vary from study to study, so be sure to check with the Field Monitor for your study for exact details.
Step # |
Action |
Menu to select |
What happens? |
1 |
Determine which fields a user should be able to edit |
N/A |
This collaborative effort between Oracle and the sponsor is completed during the design phase of the study. |
2 |
N/A |
An Oracle representative must perform this task during study design using an internal tool called the AppBlock Designer. |
3 |
N/A |
An Oracle representative must perform this task during study design using an internal tool called the Config Tool. |
4 |
Authorize the type of edits that are permitted: |
Configuration General Configurations Transaction Configurations |
Each type of change must be:
5 |
Enable editing and assign permissions for each editable field |
Configuration Transaction Configurations |
If subject data edits have been authorized, you can:
This process can be configured to require up to two levels of approval. |
6 |
Configuration Manage Visit Schedule |
The initial visit schedule is set during the design phase of the study. You can adjust the following:
7 |
Edit data during subject transactions |
Subjects All transactions |
If subject edits are authorized for the study, a user can correct subject information collected during a visit. For more information, see Roadmap: Subject visits and The process of correcting subject information in the User Guide. |
8 |
Approve or reject requests to edit subject information |
Approvals Subject approval |
If approval is required, IRT sends a notification to the user assigned to the roles that are configured to review the type of correction. For more information, see Roadmap: Approvals in the User Guide. |
