6 Upgrading Oracle Thesaurus Management System to Release 5.4.1
This chapter describes the recommended approach to upgrade an existing Oracle Thesaurus Management System installation to Release 5.4.1. Supported upgrade paths for TMS Database include:
- Release 5.0.1 or 5.0.2
- Release 5.1, 5.1.1, or 5.1.2
- Release 5.2.1
- Release 5.2.2, 5.2.3, or 5.2.4
- Release 5.3
- Release 5.3.1
- Release 5.4
Since the architecture of the technology stack changed, the supported upgrade paths for TMS Front End and TMS Report Server include:
- Release 5.2.2, 5.2.3 or 5.2.4
- Release 5.3 or 5.3.1
- Release 5.4
For other older TMS releases, a fresh installation of application tier technology stack (see Install and Configure the Oracle Application Tier), and TMS Front End and TMS Report Server (see Installing Oracle Thesaurus Management System Application Components) are required.
Be sure you are using the latest documentation:
For any known installation issues, see Known Installation and Configuration Issues for Oracle Health Sciences products Oracle Clinical, RDC Onsite, and TMS version 5.x (Document ID 1572864.1) on My Oracle Support.
To ensure that you have the latest version of this guide, see the Oracle Thesaurus Management System documentation page on the Oracle Help Center at https://docs.oracle.com/en/industries/health-sciences/thesaurus-system/5.4.1/index.html.
For the latest Oracle Thesaurus Management System 5.4.1 Release Notes, see document ID 3004177.1 on My Oracle Support.
Review Prepare to Install Oracle Thesaurus Management System for system requirements and planning information.
Critical Patch Updates: See Download Oracle Critical Patch Updates.
Oracle Database 19c (19.3.0.0) include many new features including multitenancy,
which allows you to create one or more pluggable databases (PDBs) contained in a
single root or container database (CDB). You can install Oracle Thesaurus
Management System on either a pluggable database or a non-CDB database (as in 11g). For
more information on multitenancy, see https://docs.oracle.com/en/database/oracle/oracle-database/19/multi/introduction-to-the-multitenant-architecture.html#GUID-267F7D12-D33F-4AC9-AA45-E9CD671B6F22.
For information about upgrading and migrating your existing database, see the
"Installing and Upgrading" document at https://docs.oracle.com/en/database/oracle/oracle-database/19/install-and-upgrade.html:
For more information about new features, see Oracle Database 19c Introduction and
Overview White Paper at https://www.oracle.com/a/tech/docs/database19c-wp.pdf.
For details on 19c version, see Oracle Database 19c What's New at https://docs.oracle.com/en/database/oracle/oracle-database/19/whats-new.html.
Distributed environments are no longer supported in this release.
This chapter includes:
- Upgrade Oracle Clinical (If Integrated with Oracle Clinical)
- Back Up Your Database(s)
- Upgrade the Database to Oracle Database 19c (19.3.0)
- Upgrade and Configure the Application Tier Technology Stack
- Install the TMS Database Server Code
- Upgrade a TMS Database
- Upgrade Cloned Databases
- Run Scripts to Gather Schema Statistics for the 19c Optimizer
- Upgrade the TMS Front End
- Update the TMS_HELP_URL Property for Online Help
- Upgrade the TMS Reports Server
