3 Configuring Enterprise Templates
Prerequisites for Configuring Enterprise Templates
The DFLT_<ENTERPRISEID> enterprise template is seeded for the setup of global
(chain-level) configuration. Typically, only one enterprise template is required to
distribute global configuration to all chains and properties in your enterprise. Multiple
enterprise templates can be configured, however activating this setting (Configuring Enterprise
Settings) requires that all properties associated with one Chain Code must be
associated to the same enterprise template.
For each enterprise template created, a Manage Enterprise Template sub task is auto-created in the Enterprise Template task group; assign this task to user groups for user access to the template. See Managing User Groups.
The list of configuration types is independent of the OPERA Controls enabled in the template.Adding Enterprise Templates
Tip:
Configuration types with no dependencies follow an alphabetical order and appear below other configuration types with dependencies within the Configuration Group. Configurations types with dependencies are listed at the bottom of the list, in order of dependencies within the Configuration Group.
From the Side Menu, select Manage Enterprise Template.
Click Create and enter the following details:
Code: Enter a code for the enterprise template.
Description: Enter a description for the enterprise template.
Click Expand All to expand all Configuration Groups.
Select the Configurations tab to add configuration to the template.
Use the search field to locate a configuration option by name.
Select configuration Categories and configuration Types to include in the enterprise template.
Select the OPERA Controls tab to setup OPERA Controls in the template.
Use the search field to locate OPERA Controls by name or description.
Select a Group, then select Functions or Parametersto expand the list.
Select the OPERA Controls to include in the enterprise template.
Click Create.
Editing Enterprise Templates
Select the enterprise template code in the search result then click Edit
Select a Group, then select Functions or Parameters to expand the list.
Click Update.
