Changing Function Space
Use this utility to change the code associated with a function space and update all relevant events.
  1. From the Toolbox menu, select Utilities, select Data Management then select Change Function Space Code.
    1. Property: Enter or select a property.
    2. Code: Select a function space from the list.
    3. New Code: Enter a new code for the function space
  2. Click Change Function Space Code.
