HTTP Links
A number of user interface pages can be made to display context-specific navigational links to other applications. These pages show a "Links" drop down menu, showing the list of (configured) links as menu items provided the condition on the respective link definition is met. When clicking on one of these links, the browser opens a new tab for the generated URL. The URL itself is generated by a dynamic logic function that has access to the following elements:
hard coded parts
the context from which the link is clicked
The context will often be the object in the master block of the UI, but can sometimes differ; it is described in detail for each UI page where the HTTP link is configurable. When the context object is multi record, the current row provides the data that can be used in assembling the HTTP link. -
environment settings
Because a property in the config file can be read in dynamic logic, identical dynamic logic may result in different links across multiple environments. This way, it is easy to switch between environments without having to change the dynamic logic.
Both the reporting tool (or any other tool for that matter) and the contents of the report are out of scope, it is only the navigation and the configuration that is provided for.
HTTP Link
A HTTP link has the following attributes:
| Field | Description |
Page |
The page from which the HTTP link can be started. |
Display name |
The display name of the HTTP link. |
Display sequence |
The display sequence of the HTTP link. |
Condition |
A reference to the condition dynamic logic which determines if the HTTP link should be displayed in the page. |
Enabled? |
Is the HTTP link enabled? |
Function dynamic logic |
A reference to the function dynamic logic that assembles the HTTP link. |
The logical key consists of the combination of page and display name.
Configuration for HTTP links is supported for the following UI pages:
| Component | Function code | Page | Input object |
OHI Claims |
Various* |
Claim pages |
Claim |
OHI Claims |
CL0022 |
Authorizations |
Authorization |
OHI Claims |
CL0055 |
Adjudication Cases |
Adjudication Case |
OHI Claims |
CL0053 |
Adjudication Limit Counters |
Limit Counter |
OHI Claims |
CL0085 |
Provider Limit Counters |
Provider Limit Counter Period |
OHI Product Definition |
PR0026 |
Setup Product |
Product |
OHI Authorizations |
AU0005 |
View and Edit Authorizations |
Authorization |
OHI Enterprise Policy Administration |
PO0001 |
View and Edit Policy |
Policy |
PO0045 |
View Person |
Person |
When configuring a HTTP link for Claim page, the link will be shown in all pages for a single working copy claim:
CL0028 View Claim
CL0139 Enter Claim
CL0012 Change Claim
CL0029 Manual Pricing
CL0115 Manual Pricing Adjudication
CL0030 Manual Benefits
CL0031 Manual Adjudication
