Adjudication Case Integration Point
The Adjudication Case Integration Point provides the ability to start and end adjudication cases from an outside source. This can be used for the following purposes
to migrate historical cases from an old system to OHI Claims.
to open an adjudication case as result of a transaction in another system. This can be used to
open an adjudication case when an authorization is used as the evidence for the fact that the person or object is in an adjudication case and that certain procedure codes for the person or object should be seen as ancillary to this authorization induced adjudication case.
open an adjudication case that is triggered by a claim line in another claims adjudication system.
Design principles
This interface is implemented by XML messages. The XML messages are defined in pairs using XML schemas (XSDs). Each pair of messages consists of a request and a response. Request messages are sent by external interfaces. Each contains details an adjudication case that be needs to be recorded or updated in OHI Claims. For each request message that an external interface sends, exactly one response message is returned. The response message will return 'S' (Success) if the adjudication case has been successfully inserted or updated. It will return 'F' (Failure) if the insert or update was not successful accompanied by one or more result messages to provide further details.
External interfaces will determine when request messages are sent and what data they contain. This chapter does not discuss logging, time stamps and message (correlation) identifiers (e.g. as needed for matching a given response message with its request message). These aspects are covered by the overall messaging framework.
Note that this change does not allow for the Read and Write of external consumption to an Adjudication Case. This needs to be catered for in a change to the Counter Integration Point.
Request
If the adjudication case does not exist a new case with the specified details is opened. For new adjudication cases, a primary case detail is mandatory.
If an adjudication case with the same case definition, person or object code and start date already exists the existing adjudication case is updated. This is done in the following way
End date
The registered end date is replaced by the end date in the write case request. When the end date in the request is empty and the registered end date is populated then the registered end date is nullified. When ancillary claim lines are attached to an adjudication case and the end date is updated in such a way that the service date of the ancillary claim line is now outside of the period of the adjudication case then the update will still take place without automatically reprocessing the ancillary claim lines. If an existing, partially overlapping case for the same serviced person or object and case definition exists, then either the existing case is end dated one day prior to the start date of the new case or the new case is end dated one day prior to the existing case.
Adjudication case details
If a list of adjudication case details is sent then all the existing adjudication case details are replaced by the new list. If the list of adjudication case details is not present in the request, so if there is no adjudicationCaseDetails element, the current adjudication case details are kept. This only applies to adjudication case details that have been sent in through this Adjudication Case Integration Point. Adjudication case details that link internal claim lines to an adjudication case are neither removed nor automatically reprocessed as a result of the replacement of the external adjudication case details.
Provider Group Scope and Ind Denied
When a new case is inserted and a external primary claim line is specified, OHI Claims needs to know whether the primary external claim line was denied and how to evaluate the provider group scope inheritance for ancillary lines. For this reason, an external primary claim line needs to inform OHI Claims with respect to the provider group scope and the denied indicator. Likewise, this information should not be given for ancillary external claim lines. These validations are done though business rules.
Once used by claims processing for ancillary internal claim lines, this information can be updated through the Adjudication Case Integration Point, but it will not have effect by means of automatic reprocessing. Consider the following situation
An adjudication case has been sent in through the integration point and this adjudication case is used to attach ancillary internal claim lines.
These internal claim lines have either inherited the provider group scope or have been denied because of the denied indicator.
The adjudication case is updated through the Integration point and the value for the provider group scope or the denied indicator are changed
Then these changes in provider group scope and/or denied indicator will have no effect on the ancillary internal claim lines.
Remove
Adjudication cases cannot be removed nor invalidated through this integration point.
<writeCaseRequest
<adjudicationCase
caseDefinitionCode=""
startDate=""
endDate=""
<dynamicFields/>
</adjudicationCase>
<adjudicationCaseDetails>
subtype="P/A"
externalDescription=""
providerGroupScope="I/O"
indDenied="Y/N"
transactionSourceCode=""
referenceCode= ""
<dynamicFields/>
</adjudicationCaseDetail>
</adjudicationCaseDetails>
</writeCaseRequest>
Response
The structure of the response message is as follows:
<writeCaseResponse
startDate=""
endDate=""
<resultMessages
result=""
<resultMessage
code=""
messageText=""
</resultMessage>
</resultMessages>
</writeCaseResponse>
The following messages may be returned in the response:
| Code | Sev | Message |
CLA-IP-CASE-001 |
Fatal |
Case definition code {0} is unknown |
CLA-IP-CASE-002 |
Fatal |
Insurable entity identified by code {code} and type {code} is unknown |
GEN-TMVL-003 |
Fatal |
{0} should be later than or the same as {1} |
CLA-IP-CASE-003 |
Fatal |
An adjudication case should contain a primary line |
Registering a case
John Doe with person code JD678123 has been admitted into a hospital for a long term admission. This has been registered in the old Claims adjudication system. The employer group for John Doe is now migrated to OHI Claims. In that context the adjudication case for the admission has to be migrated. This is done by sending the following request to OHI Claims.
<writeCaseRequest
<adjudicationCase
caseDefinition="HOSPADMISSION"
startDate="2011-07-01"
</adjudicationCase>
subtype="P"
externalDescription='Transferred from claim 987123, line 3'
providerGroupScope='I'
indDenied='N'
transactionSourceCode="OLDCLAIMS"
referenceCode= "987123-3"
subtype="A"
externalDescription='Transferred from claim 987189, line 2'
referenceCode= "987189-2"
</writeCaseRequest>
Updating the end date of a case
When a case has initially been registered without an end date and this end date needs to be set, or an existing end date needs to be changed, then this can be done by sending a request for the specific case definition, person and start date with a populated end date.
To set the end date for the previous request
<writeCaseRequest
<adjudicationCase
endDate="2011-09-30"
</adjudicationCase>
</writeCaseRequest>
This sets the end date of the adjudication case to september 30th, 2011.
To change the end date for an adjudication case the following request can be sent.
<writeCaseRequest
<adjudicationCase
endDate="2011-10-31"
</adjudicationCase>
</writeCaseRequest>
This updates the end date of the adjudication case to october 31th, 2011.
To erase the end date the following request can be sent.
<writeCaseRequest
<adjudicationCase
endDate=""
</adjudicationCase>
</writeCaseRequest>
Registering a case for an authorization:
The registration of a case for an authorization is similar to the registration of an adjudication case for migration purposes. Note however that the logic to decide when an adjudication case for an authorization needs to be created is situated in the integration handler between the Authorization Component and OHI Claims, so this logic does not reside in OHI Claims.
<writeCaseRequest
<adjudicationCase
caseDefinition="HOME_HEALTH_CARE"
endDate="2011-08-20"
</adjudicationCase>
subtype="P"
externalDescription='Authrozation 566512'
indDenied='N'
transactionSourceCode="AUTH_SYS"
referenceCode= "566512"
</writeCaseRequest>
