Benefits Adjudication
This step evaluates the external intervention rules for the manual adjudication of benefits.
Recalculate Claim
Claims that are both internally priced and adjudicated for benefits can sometimes trigger a recalculation at this point in the flow. This happens if at least one claim line was successfully priced (no fatal messages attached during the pricing step) based on a provider limit (consumption with the Ignored indicator cleared is taken on a provider limit), but was denied after pricing (in the Set Claim Line Status step it is described when a claim line is denied). Because the line is denied, the consumption that it took during the pricing step is returned to the limit so that other lines - within the same claim - are repriced with that consumption available.
For these lines the Ignored indicator on the preliminary provider limit consumptions is selected and all results are kept. All other non-replaced and non-locked claim lines are recalculated based on their Keep Benefits and Keep Pricing indicators.
| Keep Pricing | Keep Benefits | Action |
N |
N |
Y |
N |
Y/N |
Y |
Retain all results |
After the recalculation, the end-pricing (only if the claim was internally priced) and end-benefits derivation rules[1] are reevaluated and the total allowed amount and the total covered amount are updated accordingly if they had a value (not null):
total allowed amount is set to the sum of the claimLine.allowedAmounts of non-replaced claim lines
total covered amount is set to the sum of the claimLine.coveredAmounts of non-replaced claim lines
Evaluate External Intervention Rules
Check the Existing Pend Reasons
At this point in the process flow the claim [2], bill, and claim lines can have unresolved adjudication only pend reasons from a previous adjudication. If that is the case, the application "pends" the claim, meaning the claim’s status is set to Manual Adjudication (or Manual Pricing Adjudication)].
Auto-Resolve Pends
The application re-evaluates the external intervention rules that have a pend reason with Auto Resolve? set to true. If the claim, claim line or bill successfully meets all the criterion set by the rule, then the rule is 'triggered'. The application resolves the pend if the condition does not apply.
Evaluate the External Intervention Rules
The application evaluates all external intervention rules of the subtype MANUAL ADJUDICATION, regardless of already existing unresolved 'adjudication only' pend reasons.
It is also possible that a locked claim line pends by an existing unresolved 'adjudication only' pend reason on the claim line.
For each triggered external intervention rule, the specified pend reason is evaluated. If the re-attach indicator is cleared and the pend reason history indicates that the same pend reason has been previously attached on the same level (claim, bill, or line), then the pend reason is not attached and the claim does not pend because of this external intervention rule. Otherwise, the specified pend reason is attached to the claim, claim line, or bill and added to the claim pend reason history.
If no pend reasons are attached as a result of the external intervention rule evaluation, then the claim skips ahead to the "Set Claim Line Status" step. Otherwise, the claim status is set to MANUAL ADJUDICATION.
For more information about configuring external intervention rules, see external intervention rules and pend reasons.
Manual Adjudication
If the external intervention rule that pended the claim has its Lock Claim Lines? set to true, then all non-replaced claim lines of that claim are locked for any changes. If the external intervention rule that pended a specific claim line has its Lock Claim Lines? set to false, then that specific claim line is locked for any changes.
If the claim or claim line has at least one pend reason attached, the system initiates the work item creation cycle. Queue resolution is invoked and a work item is created. See Work Item Creation.
If the claim, claim line, or bill has at least one pend reason with Publish Message? set to true, then the workflow integration point sends out a <task> event to notify a workflow management system that a new task is ready.
The event contains all pend reasons that are configured to be published. For more information, see Claims Workflow Integration Point (Fixed Payload).
The assumption is that the external workflow management system assigns a manual adjudication task to a user. The user opens the UI page for manual adjudication and can choose one of the following actions:
Change the Claim
Revert to a status that makes it possible to change the claim, for example, changing the serviced person. -
Change the Pricing Results
Revert to a status that makes it possible to change the pricing results on the claim lines. -
Change the Benefit Results
Revert to a status that makes it possible to change the benefits results on the claim lines. -
Accept the claim as processed by Claims.
Deny a single line on the claim.
Deny the entire claim.
Change the Claim
This option returns the claim to the start of the claims flow, so that the fields on the claim itself can be changed. The claim indicators "Preprocessing Done?" and "Pricing Done?" are cleared.
The claim status is set to CHANGE, and it re-enters the level 2: Receive, Enter and Change Claim flow. Note that the claim, bill and claim line pend reasons remain attached.
Change Pricing Results
This option sets the claim back to an earlier status in the flow so that the pricing results can be changed. The claim indicator "Pricing Done?" is cleared. The claim status is set to MANUAL PRICING, and it re-enters the level 2: Pricing flow. Note that the claim, bill and claim line pend reasons remain attached.
The claim pricing results can be edited in the "Manual Pricing" page.
Change Benefits Results
This option sets the claim back to an earlier status in the flow so that the claim line rule coverages can be changed. The claim status is set to MANUAL BENEFITS, and it re-enters the level 2: Benefits flow. Note that the claim, bill and claim line pend reasons remain attached.
The claim benefits results can be edited in the "Manual Benefits" page.
Submit the Claim
The manual adjudication page allows the user to change external claims data, add new claim line messages and deny individual claim lines. Denying a single line may affect the adjudication of other approved lines in the same claim. To make those changes apparent before accepting the claim, the user has the option to force a recalculation by saving the claim. For more information, see the Manual Adjudication page description.
Saving a claim before accepting provides the user with an opportunity to validate the recalculated results before the claim is released. Note that the user also has the option to deny one or more lines without saving first, before choosing one of the other available actions. Accepting the claim first saves the claim and therefore triggers the same recalculation as described above.
Accept the Claim
When a claim is accepted, the current open work item on the claim is closed. If unresolved pend reasons still exist, a new work item is created for the remaining pend reasons. If no pend reasons remain, no new work item is created. See Work Item Closure.
When a claim is accepted, the system checks whether there is an open workflow task for that claim. This is derived from a technical field on the claim. If so, the workflow integration point sends out a message to inform the workflow distribution system that the task can be closed.
Next, any resolved pend reasons are removed from the claim, bill, and claim line, and the claim is recalculated. For more information, see the Manual Adjudication page description. Note that these pend reasons are retained in the pend reason history. One or more unresolved pend reasons can remain attached to the claim, bill, or claim line. If any pend reasons remain, the claim’s status remains MANUAL ADJUDICATION. If at least one of the remaining pend reasons has the publish message indicator selected, a new workflow integration point message is sent out. In effect, a claim is not picked up by the process flow until all pend reasons have been resolved.
If no pend reasons remain, the claim continues on its way in the claims flow at the "Set Claim Line Status" step.
Deny the Claim
When a claim is denied, the submit process closes the current open work item on the claim. See Work Item Closure.
When a claim is denied, the system checks whether there is an open workflow task for that claim. This is derived from a technical field on the claim. If so, the workflow integration point sends out a message to inform the workflow distribution system that the task can be closed. All pend reasons, both resolved and unresolved, are removed from the claim, bills and claim lines. The results of benefits are cleaned up. For more information, see the Manual Adjudication page description.
After cleaning up the calculation results, the end-pricing (only if the claim was internally priced) and end-benefits derivation rules are executed a second time. The rationale is that those derivation rules are typically used to aggregate the results of the pricing/benefits calculation. Because the claim has been denied after the initial execution of the derivation rules, they have to be executed a second time. Both the end-pricing and end-benefit derivation rules are evaluated in the following order: claim line first, bill second, claim (header) last.
Set Claim and Claim Line Status
The status of a claim line is set to "DENIED" if one of following statements is true:
the claim line has no claim line coverages and has a product specific fatal message attached.
the claim line has a product independent fatal message attached.
the claim line has a deny message attached that is not overturned.
the bill to which the claim line belongs has a fatal message attached.
the claim to which the claim line belongs has a fatal message attached.
the claim to which the claim line belongs has a deny message attached that is not overturned.
Otherwise, the claim line status is set to 'APPROVED'.
Note that the status of the claim line is not set if it is already set; locked claim lines can already have a status. If the status on locked claim lines is not already set, then it is set based only on the claim line messages; messages from higher levels are ignored.
The status of the claim is set to "ADJUDICATION DONE".
| Adjudication flow applies to sub-claims in the same way as a regular claim. However, they are not relevant for large claims. |
