Required Software
The following table lists the Oracle software that is required in order to execute Oracle Health Insurance:
| Oracle Product | Version as of 3.18.2.0.x | Version as of 3.20.1.0.x | Version as of 3.20.3.0.x |
Oracle Database Enterprise Edition |
12c Release 2 (12.2.0.1) |
Either 12c Release 2 (12.2.0.1) or 19c (latest patch release) |
Partitioning (Oracle Database Enterprise Edition Option) |
Oracle WebLogic Suite for Oracle Applications (may be used only as an embedded runtime for eligible Oracle Applications) Options required with WebLogic: Oracle Coherence; Oracle TopLink; Oracle Application Development Framework (ADF) |
12.2.1.3 |
12.2.1.3 |
12.2.1.4
| For the Oracle Database and Oracle WebLogic server make sure to always apply the latest Critical Patch Updates. |
The Oracle Database and Oracle WebLogic server as well the ADF runtime libraries need to be installed. Make sure to use the "Fusion Middleware Infrastructure Installer".
Make sure to check Certifications on My Oracle Support for the following:
Certified operating systems for the Oracle Database and Oracle WebLogic server
Certified Java runtime versions
Certified browsers
The Oracle Real Application Clusters (RAC) database option can be used with OHI applications in order to achieve a high-availability setup. RAC should not be used for scalability in combination with OHI applications.
