Reinsurance
Reinsurance Setting
An enrollment product type can have one or more reinsurance settings. A reinsurance setting specifies the percentage that should be paid out to a reinsurer.
| Field | Description |
Enrollment Product Type |
The enrollment product type for which the reinsurance setting is applied |
Organization |
The organization that acts as a reinsurer |
Percentage |
The percentage of the premium that has to be payed to the reinsurer |
Alias Code |
The alias code for reinsurance (this is transferred to OHI Claims in the enrollment response if reinsurance is applied) |
Start Date |
The start date of the reinsurance setting |
End Date |
The end date of the reinsurance setting |
Constraints:
It is not allowed to have an overlap in time validity for reinsurance settings with the same enrollment product type, organization and alias code
Reinsurance Exclusion
A reinsurance setting can have one or more reinsurance exclusions. A reinsurance exclusion specifies the premium types, adjustments and surcharges that are excluded from the base amount used for the reinsurance payment calculation.
Reinsurance Setting |
The reinsurance setting for which the exclusions apply |
Premium Schedule Type |
The excluded premium schedule type |
Schedule Definition |
The excluded schedule definition |
Note that not all schedule definitions are relevant to reinsurance. For example, schedule definitions that belong to the Fee schedule definition type have no relevance within the context of a reinsurance exclusion.
Reinsurance Treaties
The following entities are used to store the reinsurance treaty related details:
Reinsurance Treaty Types
Code |
The code of the reinsurance treaty type. |
Description |
Treaty type description. |
Display name |
Display name for the reinsurance treaty. |
Code |
The code for the reinsurance treaty. |
Description |
Description of the treaty. |
Type |
The type of the treaty, reference to reinsurance treaty type. |
Retention percentage |
The percentage of the premium retained by the payer or costs per claim for the payer. |
Retention amount |
The maximum amount for which the payer is liable, typically per member or policy. |
Excess of loss amount |
The maximum amount for which the payer is liable, typically per group of policies or catastrophic event. |
Commission percentage |
Commission percentage which the payer collects from the reinsurer. |
Priority |
Priority in which the treaty is to be applied. |
Enabled? |
Reinsurance Treaty enabled?. |
Start Date |
Start date for the reinsurance treaty. |
End Date |
End date for the reinsurance treaty. |
Reinsurance Treaty Reinsurer
Reinsurer |
The organization that acts as a reinsurer. |
Percentage |
Reinsurer’s percentage split. |
Treaty |
Reference to the reinsurance treaty. |
Reinsurance Treaty Premium Scope
The included schedule definition. |
The included premium schedule type. |
Treaty |
Reinsurance Treaty Benefit Scope
Service Option Service Code |
Service codes that are included in the treaty. |
Treaty |
Reinsurance Treaty Enrollment Scope
Enrollment Product |
The enrollment product to which the treaty applies. |
Group Account Product |
The group account enrollment product to which the treaty applies. |
Group Client |
The group client to which the treaty applies. |
Treaty |
