Service Definition, Product Service Definition, and Benefit Priorities
Just as benefit specifications are based on a combination of a service definition and a product service definition, benefit priorities can also be based on the combination of a service definition priority and a product service definition priority. But this is not mandatory, benefit priorities can also be based on solely a service definition priority or a product service definition priority.
So dependent on the configured priorities three flavors are automatically created:
  • Benefit Priorities based on a service definition and a product service definition priority
  • Benefit Priorities based on a service definition priority (and no product service definition priority)
  • Benefit Priorities based on a product service definition priority (and no service definition priority)
To clarify this and the (im)possibilities, some examples are given in this document.
Using Only Product Service Definition Priorities
Consider the following example containing two product service definition priorities.
Code Short Code Display Name Priority
REGULAR
REGL
Regular Service
3
FEDERAL MANDATE
FMAN
Federal Mandate
2
This results in the generation of two benefit priorities.
Benefit Priorities
FEDERAL MANDATE
Federal Mandate
2999
REGULAR
Regular Service
3999
The value of the benefit priority is calculated as follows:
Product Service Definition Priority * 1000 + Service Definition Priority AND if either priority is missing, use value "999" for that priority
This is why the value of the resulting benefit priority is "2999" and not "2".
Combined Priorities
Using both service definition and product service definition priorities to generate benefit priorities allows for the most fine grained list of benefit priorities, as each possible combination of two priorities results in a benefit priority. Consider the following example containing two product service definition priorities.
REGULAR
REGL
Regular Service
3
FEDERAL MANDATE
FMAN
Federal Mandate
2
And two service definition priorities.
DEFAULT
DFLT
Default
5
EXCEPTION
EXCP
Exception
3
These configured (product) service definition priorities result in the generation of the following benefit priorities (ordered from high to low priority).
Benefit Priorities
FMANEXCP
Federal Mandate Exception
2003
FMANDFLT
Federal Mandate Default
2005
FEDERAL MANDATE
Federal Mandate
2999
REGLEXCP
Regular Service Exception
3003
REGLDFLT
Regular Service Default
3005
REGULAR
Regular Service
3999
EXCEPTION
Exception
999003
DEFAULT
Default
999005
For each benefit priority that is based on two priorities the two short codes are used to create the code for the benefit priority. If the benefit priority is only based on a single priority, the code of that priority is used to create the code of the benefit priority.
Incorrect Setup
It is not possible to create a service definition and a product service definition priority with the same code. This will encounter an error when benefit priorities are generated. So the following example must be avoided.
REGULAR
REGL
Regular Service
3
REGULAR
REGL
Regular Service Definition
5
In this situation the system tries to create two benefit priorities with the same code which results in a unique key violation.
