4 View data listings, display data flow, and create discrepancies
- Choose a listing type
- Customize the listings view
You can hide, pin, or reorder columns on the listings interface by using Table Settings function. Additionally, you can adjust the width of the Listings/Filters panel to view longer table names by clicking and dragging your cursor. - Search for data
- Review data
- Create discrepancies
- Reprocess discrepancies that failed to be sent
- Export data to Excel or CSV
After you select a study and open a listing, you can export the data. To export the data in a listing, click Export from the top of the listing table to open the Export Listings options. - View data flow
- Create a custom listing
- Copy a custom listing
- Use the Expression Builder
- FAQs
