Blocking and Concurrency
When investigating blocking and concurrency, you are looking for wait events. If the locks and latches described below are among the top wait events, it may indicate a problem. Check the total wait time for these events. If the wait time for these events is a significant portion of the total wait time, you will need to investigate further.
