Privileges by Role
Table 4-2 LPO Privileges by Role
| Privilege | What It Allows | Pricing Analyst | Pricing Manager | Pricing Admin | Buyer |
| Run Management | |||||
| Create LPO run | Create and configure new optimization runs, including creating runs using the Copy Run function. This privilege supports setup and execution across all stages of the main run workflow. | ✓ | |||
| View LPO run | View run details, search, filter, and review optimization information. | ✓ | ✓ | ✓ | ✓ |
| Modify run name and description | Update the name and description of an existing run. | ✓ | ✓ | ||
| Modify run strategy (Promotion/Markdown) | Change the pricing strategy associated with a Promotion or Markdown run. | ✓ | |||
| Optimize / Re-optimize run | Execute or re-execute an optimization run. | ✓ | ✓ | ||
| Delete LPO run | Delete eligible runs and their setup information and results. Non-administrative users are limited to runs they created. | ✓ | ✓ | ✓ | |
| Recommendation Management | |||||
| Modify recommendations | Accept, reject, override, or add supported Promotion, Markdown, or Regular Pricing recommendations. | ✓ | ✓ | ✓ | |
| Recalculate recommendations | Refresh forecast-dependent projected metrics after a supported recommendation change. | ✓ | ✓ | ||
| Review / Undo Review | Mark recommendations as reviewed or undo the review status. Reviewed recommendations can then be submitted or approved. | ✓ | ✓ | ||
| Submit, Approve, and Undo | Submit recommendations for downstream processing in Submitted status or approve them in Approved status. Undo either action when permitted. | ✓ | |||
| Administrative / Monitoring | |||||
| Optimize failed runs | Re-run failed optimization jobs after resolving technical or data issues. | ✓ | ✓ | ✓ | |
The Regular Price User, Promotion User, and Markdown User roles are access roles, not workflow roles. They control which optimization type a user can access rather than what actions they can perform within it. For this reason, they are not shown as separate columns in Table 4-2.
To work with a specific optimization type, a user must be assigned both the applicable access role and a workflow role (Pricing Analyst, Pricing Manager, or Buyer). Users whose responsibilities span both Promotion and Markdown must be assigned both roles.
Users who are not assigned an applicable access role cannot access the related LPO screens or Rules Management tasks in Control and Tactical Center.
