Product Map View
The Product Map view will display the first time you enter the Home Experience. This view offers a high level overview of the tasks and actions available to you, based on your security access. Each box in the Product Map may contain a folder, a link to a task flow, or an action that can be performed in another screen. If the option is a folder, another series of boxes will display in the Product Map, showing the contents of the folder. The folder will contain links to either task flows or actions that can be performed, again displayed based on your security access.
Figure 1-3 Product Map
Product Map
