Sort Options
When in a standard table view, there may be sorting buttons available next to table column headers. These buttons will allow you to sort the table data on that column in either an ascending or descending order.
Figure 2-6 Table View - Column Sorting Buttons
When in a card view, there may be a Sort By menu that will allow you to choose a desired column on which the cards should be sorted.
Figure 2-7 Card View – Sort By Menu
Once a column is selected from the Sort By menu, the selected value will be checked and will display in the Sort By menu button’s label.
Figure 2-8 Sort By Menu Expanded
