Filter Chips
Filter chips allow users to apply and combine multiple search criteria to narrow the list of locations. The search criteria are displayed as chips in the search bar. Filters are additive; each new filter further restricts the dataset based on previously applied filters.
Some of the filter chips are applicable to both types of locations. These include:
- Name
- Currency
- Country
- Tax Region
Some of the filter chips are only applicable to stores. These include:
- Store (location type)
- District
- Channel
- Organizational Unit
- Transfer Entity
- Store Type
- Stock Holding
- Store Service
- Store Condition
- Store Open Date
- Store Close Date
Some of the filter chips are only applicable to warehouses. These include:
- Warehouse (location type)
- Virtual Warehouse
If the Store (location type) filter chip is applied, only locations with a type of store will be displayed in the table. In this case, the warehouse-specific filter chips are no longer applicable. Applying any of them along with the Store filter chip would return no locations. Therefore, the warehouse-specific filters are hidden when the Store filter chip is applied. Likewise, if the Warehouse (location type) filter chip is applied, all of the store-specific filter chips are hidden. When the Store or Warehouse applied filter chip is removed from the Ask Oracle search bar, the previously hidden chips become visible again.
When you click a filter chip, it will be applied to the Ask Oracle search bar. If the chip requires you to enter or select a value, a field will display below the applied filter chip to allow you to enter, select, or search for the desired value. If you click away without entering a value, the filter chip will automatically be unapplied. Some filter chips allow only a single value to be applied at a time, while other chips such as Currency and Country allow you to select multiple values.
