Accepting or Rejecting the Order Batch
Purpose: This topic describes the processes that the system performs when you select Edit/Accept for a batch to accept the entire batch or you select Reject Batch for a batch to reject and delete the batch.
In this topic:
When to accept or reject: You accept or reject a batch of orders when you finish entering the individual orders in a batch; see Performing Batch Order Entry.
Rejecting the Batch
You may want to reject an order batch if the order batch contains orders that you wish to delete.
Select Reject Batch to reject and delete the batch. You advance to the Confirm Reject Window. Select OK to reject the batch.
The system prints the Rejected Batch Listing, deletes the orders from the system, and deletes the batch itself.
Deleted Order table: The system writes a record in the Deleted Order Table for each purged order.
If the batch includes a retail pickup or delivery order from Order Orchestration, the BROKER process sends a status update rejecting the order; also, it deletes the related Order Orchestration and Order Orchestration History records. See Retail Pickup (including Ship-for-Pickup) or Delivery Orders for an overview.
Accepting the Batch
Select Edit/Accept on the Work with Error Orders Batches Screen to edit the order batch. The system runs the same order edit that is performed when you receive orders through the Generic Order Interface (Order API) and includes any orders in error on the Print Remote Order Errors Report.
For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1).
When an order passes the order edit, the system removes the batch number from the order, updates its status to open, performs pick slip preparation, and makes it available in regular order maintenance and inquiry.
If an order fails the order edit, the system includes the order on the Print Remote Order Errors Report and retains the order in an error status in the order batch. Select Work with Orders for the order batch to advance to the Work with Error Orders Batches Screen where you can review and correct the errors on each order. When you have finished updating each order, select Edit/Accept again to edit and accept the remaining orders in the order batch.
Performing Online Credit Card Authorizations
Online credit card authorization allows you to send and receive electronically the information required to authorize a credit card at the time the order is placed instead of at the time the pick slip is generated for the order.
The system performs online authorization when you accept an order batch after determining if any order in the batch should go on hold.
If an order in the batch is eligible to receive a credit card authorization during batch order entry, the system sends the amount requiring authorization to the authorization service and waits for a response.
There are 3 types of responses you can receive from the authorization service.
  • R = an authorization response was received, such as declined or approved.
  • T = the program timed out before an authorization response was received.
  • U = an undefined response was received.
Additionally, if an authorization response is received, the authorization service sends back an authorization response code, AVS response code (if performing address verification), card security response code (if performing credit card security identification), authorization code, and date.
If a hold reason code has been defined for the vendor response, AVS response, or CID response received, the system places the order on hold.
Credit cards requiring authorizations less than $1.00: If the credit card amount to authorize is less than $1.00 and you have defined an authorization number in the Authorization Number for Authorizations Under $1.00 (I08) system control value, the system does not send the credit card to the service bureau for authorization and instead assigns the authorization number from the system control value to the credit card. If an authorization number is not defined in this system control value, the system sends the credit card to the service bureau for authorization, regardless of the amount that requires authorization.
Performing Online Verification Only: If the Online Auth Verification Only (I96) system control value is selected, the system processes online authorizations for $1.00 for the purpose of validating the card. During batch authorizations, the system authorizes the card for the shippable dollar amount and voids the online authorization for $1.00.
For more information: See Performing Online Credit Card Authorizations for an overview of the online credit card authorization process and the required setup.
Accepting an Order in the Batch
Purpose: The system performs updates to a number of tables to reflect the addition of a new order to the batch. The updates occur:
  • Immediately, as you enter an order to the batch.
  • When you accept the order or accept the order and add a recipient order.
  • During a background processing job (ORDR_ASYNC).
Immediate Updates
The system updates the SKU and Item/Warehouse tables immediately as you enter a new order to the batch.
Process Table Field
Update the Item/Warehouse record for each item ordered
Item/
Warehouse
On hand qty (if express-billed order)
ITW B/O qty
Reserve qty
S/H reserve qty
ITW On order qty
Update the SKU record
SKU
SKU Orders avail pick gen
SKU Open qty
SKU On hold qty
Additionally, the system updates the following tables as you enter a new order:
  • Customer Sold To
  • Customer Sold To Extended Address
  • Customer Sold To Phone #
  • Customer Bill To
  • Customer Bill To Extended Address
  • Customer Bill To Phone #
  • Customer Ship To
  • Customer Ship To Extended
  • Customer Ship To Phone #
  • Customer Action Notes
  • Order Additional Charges
  • Order Detail
  • Order Detail Data Queue
  • Order Free Gift
  • Order Header
  • Order I/T Lines
  • Order Information
  • Order Line History
  • Order Line Messages
  • Order Messages
  • Order Payment Method
  • Order Pending Checks
  • Order Selected Item
  • Order Ship To
  • Order Ship To Address
  • Order Ship To Data Queue
  • Order Special Handling
  • Order Transaction History
  • Reserved Order Lines
Updates at Accept
The system performs these table updates when you accept each order in the batch.
Process Table Field
Reprice order if the Pricing method field in the Source Code record is set to a Reg Plus Reprice
Order Detail
ODT Price
Evaluate free gift eligibility, based on the source code or offer; create order detail records for free gift, if applicable
Order Detail
All fields
Calculate the $ Discount, based on Source or Offer; add a record to the Order Additional Charges table
All fields
Sends balance of updates to background processing job (O/P ASYNC)
Order transaction history: When you accept an order that is part of an order batch, the system writes an order transaction history message with a Type of Maintenance indicating the user that accepted the order. The system writes an order transaction history message each time a user accepts the order so that you can track the users that changed the order in the batch prior to accepting the order batch. You can review order transaction history messages on the Display Order History Screen.
An example of the order transaction history message the system creates when a user accepts an order that is part of an order batch is displayed below. The system includes an amount regardless of whether the change updated the order total.
Date Type Transaction Note Amount User
8/14/14
MAINT
Order changed while in unaccepted batch
45.00
SFLYE
The system does not create an order transaction history message if a user rejects out of an order that is part of an order batch. If a user accepts an order in order maintenance that is no longer part of an order batch, the system writes an order transaction history message indicating: Order was maintained.
Additional updates when you accept the entire batch: The system performs these updates to the individual orders in the batch only when you accept the entire batch (see Accepting the Entire Batch):
  • Perform the credit check processes
  • Evaluate for refund eligibility
  • Update the Flash Report
  • Evaluate and update the order status based on the detail line status, if necessary
  • Update the Online Authorization, Authorization History, and Void Authorization tables if you performed online credit card authorization
  • Applies pick slip preparation to each eligible order; see Applying Pick Slip Preparation to an Order
Updates During Background Processing
The system performs the balance of the field and table updates during a background processing job (O/P ASYNC) that runs after you accept each order in the batch.
Process Table Field
Update the Price Override Reason table, based on price overrides at detail line level
POR # of overrides
POR Total discount
SKU
Date of first order
Date of last order
Update the SKU/Price History record
SKU Price History
SPH # orders
SPH $ orders
Update the SKU/Offer Page record for offer page analyses
SKU/Offer Page
Dollars ordered CTD
Dollars ordered WTD
Dollars sold out CTD
Dollars sold out WTD
Units ordered CTD
Units ordered WTD
Units sold out CTD
Units sold out WTD
SOP Dollars upsell CTD
SOP Dollars upsell WTD
SOP Units upsell CTD
SOP Units upsell WTD
SOP Units lost CTD
SOP Units lost WTD
Update the Order/Billing History record
OBH # Orders
OBH $ Order total
OBH Qty ordered
OBH # Orders sold out
OBH $ Sold out total
OBH Qty sold out
Add a record to the Soldout Notifications table to generate soldout notifications for sold-out items
Update the sold-to customer record
Customer Sold To Order History
COH On order $
COH # Orders LTD
COH # Sold outs LTD
COH $ Orders LTD
COH $ Sold outs LTD
COH Last Card Number
COH Active since date
COH Last order date
OTY Order type
PAY Pay type
SRC Source code
Update the ship-to customer record
Customer Ship To Order History
HOH On order $
HOH # Orders LTD
HOH # Sold outs LTD
HOH $ Orders LTD
HOH $ Sold outs LTD
HOH Active since date
HOH Last order date
OTY Order type
PAY Pay Type
SRC Source code
Update operator statistics, based on order type
Order Type/ User
OTU # Orders TD
OTU # Orders LTD
OTU $ Value - TD
OTU $ Value - LTD
OTU # Receipts TD
OTU # Recips LTD
OTU # Lines TD
OTU # Lines LTD
Update operator statistics by accounting period, based on order type
Order Type/ User History
OUH # Orders
OUH $ Value
OUH # Recips
OUH # Lines
Update the source code record with the accumulated order totals
Source
$ Orders
$ Soldouts
# of Orders
# of Soldouts
Purpose: The system updates several tables:
  • When you accept the entire batch
  • During a background processing job that runs automatically after you accept a batch or an order in the batch
See Working with the ORDR_ASYNC Job for more information on the background jobs.
Updates at Accept
The system performs these table updates when you accept the batch. See Performing the Release and Introducing Order Hold Reason Codes for more information about the credit check process that evaluates customers, orders, and payment types and performs record updates if any condition on the order fails a credit check.
Process Table Field
Credit check: sold-to customer unconditional hold
Order Header
SKU
OHD OHR Sys hold reason
SKU On hold qty
Credit check: sold-to customer fraud
Order Header
Order Header
SKU
OHD Order status
SKU On hold qty
Credit check: sold-to customer zip code fraud
Order Header
Order Header
SKU
OHD Order status
SKU On hold qty
Credit check: bill-to customer unconditional hold
Order Header
SKU
SKU On hold qty
Credit check: bill-to customer zip code fraud
Order Header
SKU
SKU On hold qty
Credit check: ship-to/ sold-to customer fraud
Order Ship To
Order Header
Order Ship To
SKU
OST OHR Hold reason
OST Order status
SKU On hold qty
Credit check: ship-to/ sold-to customer zip code fraud
Order Ship To
Order Header
SKU
OST Order status
SKU On hold qty
Credit check: ship-to customer fraud
Order Ship To
Order Header
SKU
OST Order status
SKU On hold qty
Credit check: ship-to customer zip code fraud
Order Ship To
Order Header
SKU
OST Order status
SKU On hold qty
Credit check: dollar hold
Order Header
SKU
SKU On hold qty
Credit check: time hold
Pay Type
Order Header
SKU
OHR Hold reason
SKU On hold qty
Credit check: check fraud
Pay Type
Order Header
SKU
OHR Hold reason
SKU On hold qty
Credit check: balance due exceeds the $ amount
Order Header
SKU
SKU On hold qty
Credit check: pay types
Order Header
SKU
SKU On hold qty
Credit check: credit card fraud
Pay Type
Order Header
SKU
OHR Hold reason
SKU On hold qty
Credit check: credit card authorization pending status
Pay Type
Order Header
SKU
OHR Hold reason
SKU On hold qty
Credit check: outstanding balance due
Pay Type
Order Header
SKU
OHR Hold reason
SKU On hold qty
Credit check: email address fraud
Order Header
Order Ship To
SKU
OHR Hold reason
SKU On hold qty
Evaluate order for refunds; create refund records for overpayments or balance dues
Refunds
All fields
Update the Operations Control Summary (Flash) Report
Order Control Summary
# Orders entered
$ Orders entered
Quantity ordered
# Orders soldout/clsd
$ Orders soldout
Quantity soldout
$ Open backordered
Quantity backordered
$ Held backordered
Qty held backordered
Update order header and order ship-to status to match status of detail lines if all lines canceled.
Order Header
Order Ship To
OHD Order status
OST Order status
Approved online credit card authorization: Create an online authorization record, authorization history record, and void authorization record if you performed online credit card authorization for a credit card payment method on the order
Void Authorization
Online Authorization:
company
order #
seq #
auth amount
vendor response 1(auth response)
vendor response 2 (CID response)
auth #
auth date
status: *UPDT
trans seq #
card number
terminal #
AVS result
card security value
ASV auth service
Authorization History:
All fields except Amount Deposited
Void Authorization:
All fields
Declined online credit card authorization: Create an online authorization record and authorization history record if you performed online credit card authorization for a credit card payment method on the order
company
order #
seq #
auth amount
vendor response
status: *SENT
trans seq #
card number
terminal #
ASV auth service
All fields except Amount Deposited, Auth Date, and Auth #
Undefined online credit card authorization response: Create an online authorization record and authorization history record if you performed online credit card authorization for a credit card payment method on the order
company
order #
seq #
auth amount
vendor response
auth #
auth date
status: *UPDT
trans seq #
card number
terminal #
ASV auth service
Online credit card authorization communication failure: Create an online authorization record and authorization history record if you performed online credit card authorization for a credit card payment method on the order
company
order #
seq #
auth amount
auth #
auth date
status: *UPDT
trans seq #
card number
terminal #
ASV auth service
All fields except Amount Deposited, Auth Date, Auth #, and Vendor Response
Clear order batch number: If the order is a membership order, an e-commerce order or a retail order, the system clears the order batch number upon acceptance. Determined by:
Order Header
OBA Batch #
For a retail pickup or delivery order, sends a status update to Order Orchestration to change the status in Order Orchestration to Accepted. Also, change the status of the Order Orchestration record to In process.
Order Orchestration
Status
Create pre-generated picks
Pick Control Header
Pick Control Detail
Pick Control Label
Pick Stored Value Card
See Applying Pick Slip Preparation to an Order for the updates that are performed
The system performs the balance of the field and table updates during a background processing job (ORDR_ASYNC) that runs after you accept the entire batch.
Process Table Field
POR # of overrides
POR Total discount
SKU
Date of first order
Date of last order
SKU Price History
SPH # orders
SPH $ orders
SKU/Offer Page
Dollars ordered CTD
Dollars ordered WTD
Units ordered CTD
Units ordered WTD
Units sold out CTD
Units sold out WTD
SOP Units lost CTD
SOP Units lost WTD
OBH # Orders
OBH $ Order total
OBH Qty ordered
OBH Qty sold out
COH On order $
COH # Orders LTD
COH # Sold outs LTD
COH $ Orders LTD
COH $ Sold outs LTD
COH Last order date
OTY Order type
PAY Pay type
SRC Source code
HOH On order $
HOH # Orders LTD
HOH # Sold outs LTD
HOH $ Orders LTD
HOH $ Sold outs LTD
HOH Last order date
OTY Order type
PAY Pay Type
SRC Source code
Order Type/ User
OTU # Orders TD
OTU # Orders LTD
OTU $ Value - TD
OTU $ Value - LTD
OTU # Recips TD
OTU # Recips LTD
OTU # Lines TD
OTU # Lines LTD
OUH # Orders
OUH $ Value
OUH # Recips
OUH # Lines
Source
$ Orders
$ Soldouts
# of Orders
# of Soldouts
