13 Order and Line Statuses
Overview: The Allow Split Order preference controls whether the lines on an Order Broker order can have different statuses.
These statuses do not apply to orders created through the Supplier Direct Fulfillment module.
In this topic:
- Order and Line Statuses (Splitting Preference Turned Off)
- Order and Line Statuses (Splitting Preference Turned On)
When the Allow Split Order preference is unselected, all order status updates apply at the order level. With this setting, the line status and the order status are always the same.
See Processing Flow for Delivery and Pickup Orders for a summary of how the Store Connect module displays statuses.
| Status | Description |
| accepted |
Integrated system: The assigned fulfilling or sourcing location has sent a status update indicating it can fulfill the order. If the system is flagged to Require Status Update, a status update message indicating that the order is accepted flags the order as polled, indicating that the order should no longer be included in the fulfillments response message. Store Connect: A store associate has accepted the new order. |
| canceled |
The order has been canceled and does not need to be fulfilled. A status update to cancel an order can come from any location. When the Routing Engine receives a status update indicating that an order is canceled, it sets the Poll Count for all order lines to 0.
| fulfilled |
The order has been:
| intransit |
The location originating assigned to source a ship-for-pickup order has sent the inventory to the location where the customer will pick up the order. |
| intransit polled |
The pickup location for a ship-for-pickup order:
Only the pickup location for a ship-for-pickup order can update the status to intransit polled. This status applies only to ship-for-pickup orders. |
| new_order |
Store Connect: New orders are automatically set to polled status when they are assigned to a Store Connect location. |
| picked |
Ship-for-pickup order: The location originating assigned to source a ship-for-pickup order is preparing to transfer the inventory to the location where the customer will pick it up. This status might also be used by the location assigned to fulfill a delivery order. Store Connect: A store associate has verified that the order has been picked. If it is a pickup order and is not under review, it is eligible for pickup, and if it is a delivery and is not under review, it is eligible for shipment. |
| polled |
The assigned fulfilling or sourcing location has been notified of the order assignment, and the order should not be included in subsequent fulfillments response messages. Only the assigned fulfilling or sourcing location can send a status update of polled. An order is assigned this status when:
Store Connect: An order first becomes visible to store associates in Store Connect when its status goes to polled. At that point, the order is first listed on the View New Orders screen in Store Connect. The Next Action displayed is Accept & Print. See Notifying Store Connect Locations about New Delivery and Pickup Orders for background. |
| posted |
The order has been posted for Order Fulfillment through RICS Integration. |
| received |
The transferred inventory has been received at the location where a customer is picking up a ship-for-pickup order. |
| rejected |
The assigned fulfilling or sourcing location has sent a status update indicating it cannot fulfill the order, or the pickup location for a ship-for-pickup order indicates that the inventory for the item was not received or was damaged in transit.
When the Routing Engine receives a status update indicating that an order is rejected, it sets the Poll Count for all order lines to 0. |
| unfulfillable |
This is a:
When a delivery order is unfulfillable, its assigned location changes to the Default Unfulfillable Location. |
Additional statuses: The Routing Engine allows the following additional statuses if they are useful for your business processes, although it does not process any additional order updates as a result of a change to any of these statuses:
- processed
- verified
- partially fulfilled
Order: If the Allow Split Order preference is selected, all status updates apply to the individual order lines regardless of the order type, and the Routing Engine determines the order status by evaluating the status of the lines.
Order-level status based on line-level status(es):
- If all of the lines on the order have the same status, apply that status at the order level; otherwise,
- If the order lines have any combination of statuses, but at least one line is in new_order, accepted, polled, picked, intransit, intransit polled, partially fulfilled, processed, verified, or received status, the order status is open; otherwise,
- If all the order lines are a combination of canceled or unfulfillable, the order status is unfulfillable; otherwise,
- If all the order lines are a combination of unfulfilled, canceled, or fulfilled, the order status is complete.
Line summary status if line is split: The Detail tab at the Order screen also uses these rules to summarize the status of a split line. A line can split if the Allow Split Line preference is selected. Also, you can split a line by processing a partial status update if the Allow Partial Updates preference is selected.
If Pickup By Date was assigned: If a Pickup By Date was assigned to the order line, changing the status to any other status removes the Pickup By Date. For example, if the current status of a pickup order line was picked, changing the status to canceled or fulfilled removes the Pickup By Date. See Auto-Cancel Unclaimed Orders for background.
| accepted |
The assigned fulfilling or sourcing location has sent a status update indicating it can fulfill or source the order line. If the system is flagged to Require Status Update, a status update message indicating that the order line is accepted flags the order as polled, indicating that the order line should no longer be included in the fulfillments response message. Store Connect: A store associate has accepted the order. |
| canceled |
The individual line has been canceled and does not need to be fulfilled. The status update to cancel a line can come from any location. When the Routing Engine receives a status update indicating that a line is canceled, it sets the Poll Count for that line to 0.
| complete |
Order or line summary status: The status of the lines on the order is a combination of unfulfillable or canceled and fulfilled. The Order screen also displays a completed status for a line at the summary level if the line is split into this combination of statuses. If none of the lines are fulfilled, then the order or line summary status is unfulfillable. Note: This is a system-assigned status; it is not possible to assign this status to an order or line. |
| fulfilled |
The line has been:
| intransit |
The location assigned to source a ship-for-pickup order has sent the inventory to the location where the customer will pick up the order. |
| intransit polled |
The pickup location for a ship-for-pickup order line:
| new_order |
Indicates that:
Store Connect: A new order’s status automatically changes to polled, and the order is listed on the New Orders screen in Store Connect. See Notifying Store Connect Locations about New Delivery and Pickup Orders for background. |
| open |
Order or summary status only: At least one line on the order is in new_order, accepted, polled, picked, intransit, intransit polled, partially fulfilled, processed, verified, or received status. The Order screen also displays an open status for a line at the summary level if the line is split into this combination of statuses. Note: This is a system-assigned status; it is not possible to assign this status to an order or line. |
| picked |
Ship-for-pickup order: The location assigned to source a ship-for-pickup order line is preparing to transfer the inventory to the location where the customer will pick it up. This status might also be used by the location assigned to fulfill a delivery order. Store Connect: A store associate has verified that the order has been picked. If it is a pickup order and is not under review, it is eligible for pickup, and if it is a delivery and is not under review, it is eligible for shipment. Pickup By Date assignment: If the organization is configured to Auto-Cancel Unclaimed Orders, a Pickup By Date is automatically assigned when a line’s status changes to picked if the order type is pickup, or if the order type is ship-for-pickup and the sourcing location is the same as the pickup location. See Auto-Cancel Unclaimed Orders for background. |
| polled |
The assigned fulfilling or sourcing location has been notified of the order line assignment, and the line should not be included in subsequent fulfillments response messages. Only the assigned fulfilling or sourcing location can send a status update of polled. A line is assigned this status:
Store Connect: New orders are automatically set to polled status when they are assigned to a Store Connect location. See Notifying Store Connect Locations about New Delivery and Pickup Orders for background. |
| posted |
| received |
The transferred inventory for an order line has been received at the location where a customer is picking up a ship-for-pickup order. Pickup By Date assignment: If the organization is configured to Auto-Cancel Unclaimed Orders, a Pickup By Date is automatically assigned when a line’s status changes to received if the order type is ship-for-pickup and the sourcing location is different from the pickup location. See Auto-Cancel Unclaimed Orders for background. |
| rejected |
The assigned fulfilling or sourcing location has sent a status update indicating it cannot fulfill the order line, or the pickup location for a ship-for-pickup order indicates that the inventory for the item was not received or was damaged in transit.
When the Routing Engine receives a status update indicating that a line is rejected, it sets the Poll Count to 0. |
| unfulfillable |
This is a line on a:
When a delivery or ship-for-pickup order is unfulfillable, its assigned fulfilling or sourcing location changes to the Default Unfulfillable Location. Order or line summary status: All of the lines on the order are a combination of canceled and unfulfillable. The Order screen also displays an unfulfillable status for a line at the summary level if the line is split into this combination of statuses. |
- processed
- verified
