Accessing Back Office Employee Maintenance Functions
After logging in to the Back Office (see Accessing the Back Office), select the Employee Maintenance and Payroll option and press Enter.
Figure 4-1 Back Office Main Menu - Employee Maintenance and Payroll Option
Access a menu option with a single keystroke. Just press the keyboard number or letter associated with any menu option to use that function.
At the Employee Maintenance and Payroll menu, select one of the options and press Enter.
The following options are available:
Employee Maintenance - Select this option to maintain employee records. Refer to Maintaining Employee Information.
Time and Attendance - Select this option to maintain employee timecard and payroll information. Refer to Payroll and Timecard Maintenance.
Employee Scheduling Maintenance - Select this option to create and edit employees' work schedules and manage employees' time off. Refer to Employee Scheduling.
Task Maintenance - Select this option to create and maintain employee tasks. Refer to Message Maintenance and Task Management.
Message Maintenance - Select this option to create and maintain employee messages. Refer to Message Maintenance and Task Management.
