Daily 24/7 Flows
For systems using 24/7 trading, the register open process must be performed on each register every day. Depending upon the configuration of your system and the time that the register is opened, the system may prompt you to open the register for the previous day or the next day.
You have different options to configure the system about the desired process in the 24–hour environment. During the 24–hour flow, the system may ask the cashier to re-open the register during the close register process automatically. Alternatively, the register is not opened automatically, which would require the cashier to log in to open the register.
Depending on your system's configuration, the float can be configured so:
the cashier is prompted to enter the float amount
the cashier starts with the pre-defined float
the remaining cash balance on the register being carried over as the new float amount
the remaining cash currencies being adjusted to the approximate default, known as the Float Balance
Once the float has been defined, the register is open, and the new retail session has begun.
After an open register is approaching the end of a retail period, Warning Messages are displayed to encourage the closing of the register and to move to the next retail period. You can continue to perform transactions on the register until the end of a configurable grace period. At the end of the grace period, you must close the register. This ensures that all the registers are moved forward to the next retail period.
The rolling close process is separated from the register reconciliation process in a register accountability configuration. This means that register reconciliation is not required before closing a register or retail period.
If the register is configured to open automatically after the Register/Till Close process without user interaction, you may be prompted to enter a new amount, or a new till is inserted into the drawer with a pre-determined float amount.
Use the following steps to complete a full daily cycle:
Register/Till Open
To open a register that is configured for 24/7 trading, follow these steps:
When you attempt to log in to the system, Xstore Classic determines the status of the register and store. If the register status is closed, a Register Closed message displays if configured to do so. Press OK to close the message.
Figure 10-1 No Access - Register Closed
The red register indicator on the status bar also shows that the register is closed.
Figure 10-2 Status Bar - Register Closed
If you are using a touchscreen, tap the red register status bar to open the register. The focus bar prompts for your employee ID and password. Enter the information when prompted. Proceed to step 7.
Select the Back Office option on the Register menu to open the register from the Back Office Main Menu.
Access to the back office functions is controlled by security levels. You must have the correct security privileges to access the Back Office.
Xstore Classic prompts for your employee ID to log in to the back office. Enter your employee ID and then press Enter.
Figure 10-3 Back Office Login
If your system is set up to use a Biometric Fingerprint device, an Employee ID Login prompt displays. Use the device to scan your fingerprint rather than entering your user ID and password.
Scanned and keyed entry is also supported at this prompt.
Xstore Classic prompts for your employee password to complete the login process. Enter your employee password and then press Enter.
At the Back Office Main Menu, select Till and then the Open/Close Options option and press Enter, or press the number associated with the menu option on the keyboard to display the Open/Close Options menu.
Figure 10-4 Till Menu - Open/Close Options
At the Open/Close Options menu, select the Register Open option and press Enter, or press the number associated with the menu option on the keyboard.
Figure 10-5 Open/Close Options - Register Open
The Register menu option toggles between Open and Close. If the available menu option is Register Close, the register is currently open. If the available menu option is Register Open, the register is currently closed.
Xstore Classic prompts: Do you want to open this register? Press Yes to confirm that you want to open this register.
Figure 10-6 Register Open Prompt
The following prompts are optional depending on your configuration:
If your register has more than one cash drawer, you are prompted to select the drawer from a list of available cash drawers.
The system may be configured to print a Register Open receipt.
Depending upon your system configuration, there are different float options when opening the till:
For example, if Prompt for Float is configured, all money is removed during close. A new till is inserted and counted during open. You are required to enter the float value.
If Pre-defined Float is configured, all money is removed during close. A new till is inserted during open but not counted. You are prompted to insert the till. The float amount of the till is displayed.
Figure 10-7 Pre-defined Float Amount
Press OK to confirm the float amount.
Press Change Float to enter a new float amount for the till.
You are prompted for a reason.
Figure 10-8 Change Float
Select the reason and press OK.
You are prompted to enter a comment.
Figure 10-9 Add Comment
If necessary, enter additional comments and press OK.
Select a currency to change.
Figure 10-10 Change Float Select Currency
Enter the new amount in the Change Float Amount field.
Figure 10-11 Change Float Amount
Press the Enter button.
Click Yes to confirm the new amount. Return to the Insert Till screen.
If necessary, click Change to repeat these steps for a different currency.
If the Carried Over Float Amount is configured, all cash is left in the drawer and you are prompted to remove all non-cash tenders (that is, checks, traveler's checks and so on). During the register open process, the end balance of the register during the register close process is carried over to the next retail period as the new float amount. You are not prompted to count the drawer at register open.
If Float Balance is configured, during the register close process, you are prompted to perform a cash pickup to skim the till to match the approximate float amount. You are also prompted to remove all non-cash tenders (that is, checks, traveler's checks and so on).
If there are suspended transactions from the previous retail period, the transactions are displayed. Press OK to cancel these transactions.
You can configure the time period to look back when searching for suspended transactions. By default, all suspended transactions older than 12 hours are cancelled.
You can start your sales transactions as the new retail session has begun.
Reconcile Register/Till
Register/Till reconciliation is performed separately from the Register/Till Close process and is used to count drawers after the register is closed. It is not necessary to reconcile before the register is opened again and can be performed later.
Reconcile Register is used when in Register Accountability mode and Reconcile Till when in Till Accountability mode.
In a register accountability configuration, it is not mandatory to complete register reconciliation before closing a register or business period. To begin the register reconciliation process, at least one register must be closed.
At the Back Office Main Menu, select Till Maintenance and press Reconcile Register/Till.
Figure 10-12 Till Maintenance Options
The Closed Register Summary list displays.
Figure 10-13 Closed Register Summary
Select a till to reconcile. Each one is counted individually.
Figure 10-14 Reconcile Register
Select Yes to confirm the correct register is selected.
All available tender types are displayed in the Count Summary screen, with the following amounts.
Declared Amount: The declared amount is the amount you enter in the Denomination Count screen.
System Amount: The system amount is the expected amount from the system.
Over/Short Amount: The over/short amount shows the difference between system and declared amount.
Figure 10-15 Count Summary
You are prompted to select a tender type for the till reconcile.
Select a tender type and press Select Count.
Depending on the configuration of the selected tender type, the displayed screens vary.
The Denomination Count screen appears.
Figure 10-16 Denomination Count
You are prompted to select a denomination and enter the quantity.
Select a denomination. Enter the quantity and press Confirm Entry. The amount for the denomination and the total amount is displayed on the Sales Display Panel.
Figure 10-17 Denomination Count After Entry
Repeat this process for all available denominations.
After you have entered all denominations for the tender type, press Complete. The system returns to the Count Summary.
If no denominations are configured, the Total Count screen appears.
Figure 10-18 Totals Count Screen
You are prompted to enter the total count for the selected tender type.
Enter the total count and press Confirm Entry. The count is displayed on the Sales Display Panel.
You are prompted for the total amount of the selected tender type.
Enter the total amount and press Confirm Amount. The total amount is displayed on the Sales Display Panel.
Then select Complete. The system returns to the Count Summary.
If the Check tender type is selected to count, the Totals Count screen is displayed.
Figure 10-19 Check Tender Type
You are prompted to enter the serial number for the tender type.
Enter the serial number and press Confirm Entry.
You are prompted for the amount of the selected tender type.
Enter the amount and press Confirm Amount. The serial number and the entered amount are displayed on the Sales Display Panel.
Then press Complete. The system returns to the Count Summary.
Use the Remove Count button to remove an entered count from the Sales Display Panel.
Depending on whether or not your till is out of balance the displayed message varies.
Out of balance: If tender types are out of balance, you are prompted to accept the difference.
Figure 10-20 Out of Balance Example
Yes - accept the difference and close register.
You are prompted for the reason. Select the reason and press OK.
You can also add additional comments. Enter a comment and press OK.
No - repeat till count again.
In balance: If all entered tender types are in balance, an Information prompt "Till is in balance" is shown.
Figure 10-21 Till in Balance
Press OK to close the Information prompt.
The register/till is reconciled.
Once all the registers are reconciled within a retail period, you can perform End Retail Period.
Warning Messages
Warning messages inform you that the end of retail period is approaching, and you should start the Register/Till Close process. The default time frame for the 24/7 rolling close functionality is 24 hours (but this can be configured). A grace period allows you to close the register within a configurable gap. Once the grace period has ended, you must close the register and move to the next retail period. The following messages are displayed.
By default, a warning message is displayed one hour before the end of the retail period. This message appears at the beginning of a transaction, every 10 minutes until the register close process has been started.
The time frame for the warning messages is configurable.
Figure 10-22 End of Retail Period Approaching Warning
When the configured end of retail period time has passed, another message is displayed on each register. The message informs you that the retail period has expired and that you must close the register.
Figure 10-23 Retail Period Expired
If you try to open a register within the warning or grace period (two hours by default), you are prompted if you want to change to the next retail period, or if you want to open the register within the current retail period.
Select Next to open the register in the next available retail period.
The register is closed and moved to the next retail period. You cannot re-open the previous retail period.
Select Current to open the register within the current retail period.
After the configured store hours’ time frame and the grace period have passed, all registers that have not been moved to the next retail period are locked. You cannot start new transactions.
You receive a warning message that you cannot start new transactions within the current retail period. You must close and open the register again to start a new transaction.
Figure 10-24 No New Transactions
Register/Till Close
Rolling Close must be configured in order to remove the Count Process from the Register Close. Close each individual register one at a time manually without the need for till reconciliation. Count the drawer, denominations, and if required open the register again.
The register close process must be performed on each opened register for it to be rolled over into the next day.
Near the end of day, (that is, close to or after the required close time), warning messages will appear on remaining open registers. If a register continues to stay open past the required close time, the register will eventually prevent the user from utilizing the register until it is closed and reopened for the next day. See Warning Messages.
To close a register for the retail session:
From the register to be closed, select the Back Office option on the menu. Follow any prompts to log in to the Back Office as required.
At the Till menu, use the up and down arrow keys to select Open/ Close Options and press Enter, or press the number associated with the menu option on the keyboard.
Figure 10-25 Till - Open/Close Options
Oracle Point of Service displays the Open/Close Options menu. Select the Register Close option and press Enter, or press the number associated with the menu option on the keyboard.
Figure 10-26 Open/Close Options - Register Close
Note that the Register option toggles between Open and Close. If the option is Register Close, the register is currently open. If the option is Register Open, the register is currently closed.
Xstore Classic displays a confirmation prompt: Do you want to close this register? Press Yes to close the register. If the message is not configured, continue with step 5.
Figure 10-27 Close Register
You will need sufficient security privileges to close the register.
Pressing No at the Register Close confirmation prompt cancels the register close process and returns you to the Open/Close Options menu.
The cash drawer opens.
Depending upon the configuration of your system, you may be prompted to either remove all non-cash tenders from the till or remove all the till contents. Follow the instructions on the screen, then click OK to continue.
For example, if Prompt for Float or Pre-defined Float is configured, all money is removed during close.
Figure 10-28 Remove Till Prompt
If Carried Over Float Amount is configured, all cash is left in the drawer. You are prompted to remove all tenders, except for the default cash tenders (that is, checks, traveler's checks and so on). You are informed that the remaining balance will be the new float amount for the next retail period. You are not prompted to count the drawer.
Remove the corresponding tenders. Press OK to close the message.
If Float Balance is configured, during the register close process, you are prompted to perform a cash pickup to bring the float down to match the approximate default float amount.
You are prompted to remove all non-cash tenders from the cash drawer (that is, checks, traveler's checks, and so on), and the excess amount above the configured threshold float. You are informed that the remaining tenders are adjusted to the approximate default float amount.
Remove all necessary tenders. Press OK to close the message.
Change the suggested amount or confirm the suggested amount with Enter.
Move the money to the cash deposit bag or safe.
If the till amount needed to be picked up, is less than or equal to the configured float amount, no cash pickup is needed, and this step is omitted.
If multiple currencies are configured, this step is repeated until all float currencies have been completed.
The system may be configured to print a Closed Count receipt and a Register Closed receipt.
Close the cash drawer and the system closes the register.
After the register close is complete, you may be prompted whether to re-open the register.
Figure 10-29 Register Open Prompt
Click No to keep the register closed.
Click Yes to re-open the register.
New Business Period
The processes that typically happen behind the scenes during a traditional store close process happens when the first register is opened in a new retail period.
Define Float
How the float is handled when opening/closing a register can be configured in one of the following ways:
Prompt for Float
If the function Prompt for Float is enabled, all money is removed during close. A new till is inserted and counted during the register open process. The value of the float is entered.
At the register close you are prompted to remove the till, but no counting of the drawer is done at this time.
Pre-defined Float
All money is removed during close, but you are not prompted to count the drawer. A new till is inserted during open, but not counted.
During the register open process, you are prompted to insert a new till into the drawer which includes a pre-configured till amount. There is the option to Change Float if required.
All cash is left in the drawer, but you are prompted to remove all non-cash tenders such as checks. The balance of the register amount during register close will carry over to the next business period as the new float amount.
During the register open process, the end balance of the register during the register close process is carried over to the next retail period as the new float amount. You are not prompted to count the drawer.
Float Balance
During the register close process, you are prompted to perform a pickup of the excess money above the configured float amount. During close, enough money is removed to bring the float down to the approximate default float. The prompt 'Remaining currencies will be adjusted to the approximate default float' is shown.
