Inventory Replenishment Document
This section describes the Inventory Replenishment options:
Searching for a Replenishment Document
At the Inventory Replenishment search form, enter your search criteria:
Figure 3-3 Document Search Form
Scan or enter a specific Inventory Replenishment Request #
Enter Start and/or End Dates
Select one or more Status options:
Open
Submitted
Confirmed
Enter a Source Entity
Scan or enter an Item Id
Select Process to display Inventory Replenishment Documents that match your search criteria.
More information about document searches:
If you know a Replenishment Document does not exist, you can select the Add New option at the Document Search form (Figure 3-3) to create a new Inventory Replenishment Document. Refer to Creating a New Inventory Replenishment Order for more information about creating a new Inventory Replenishment Document at the store.
If the document you are looking for is not found in the list of Replenishment Documents, select the Add New option at the Inventory Replenishment Document Search Results form (Figure 3-4) to create a new Inventory Replenishment Document. Refer to Creating a New Inventory Replenishment Order for more information about creating a new Inventory Replenishment Document at the store.
Select the Replenishment Document you want to view from the list and press Enter.
Figure 3-4 Inventory Replenishment Document Search Results
Xstore displays the Replenishment screen for the selected document.
Figure 3-5 Inventory Replenishment Screen
This screen shows the following information for the Inventory Replenishment Document:
Replenishment Document identifier
Request Date
Requestor ID
Store Number
Created: (Store or Home Office)
Status of the shipment: (OPEN, SUBMITTED, CONFIRMED, PARTIALLY RECEIVED, CLOSED)
Items: how many unique items are in the order
Units: total number of items in the order
Weight (lbs): total weight of the order. This is only available if each of the items has a weight identified.
Comments
For each item:
Item ID
Description
Source Id
Pack Size
On Hand Qty
Suggested Order
Order Qty
Confirmed
Shipped
Received
Inventory Replenishment Order Status Definitions
An Inventory Replenishment order can be in one of the following statuses:
OPEN: This is the initial status that an order is in after being created in Xstore or when sent as a suggestion from the Home Office. This is the only status an order can be in to update or edit.
SUBMITTED: The order can go into a SUBMITTED status when all items in the order are approved.
CONFIRMED: Home Office can send orders down in a CONFIRMED status which means they are not suggestions and are not changeable.
PARTIALLY RECEIVED: When any item in the order is received, but not all items, the order is PARTIALLY RECEIVED. See Inventory Replenishment for more information on Receiving Inventory Replenishment orders.
CLOSED: The order is considered CLOSED when all items are received, or the order is Force Closed.
CANCELLED: Home Office or the Store can cancel an order. Once cancelled it cannot be edited or re-opened.
