Address Lookup
Address Lookup allows users to quickly locate accurate addresses using minimal information, instead of manually keying the entire address. When enabled, this function is available in most Xstore Point of Service address capture screens, including handheld and tablet.
The Address Lookup function may not be available for all countries.
To use address lookup:
Select the Address Lookup function.
The Address Lookup window opens.
Enter the first line of the address, followed by the postal code.
The search terms used in some countries can be different, and several different search terms can be used within a country. For example, instead of a postal code, some countries can search using a city or town and a state or province. Or, in some countries, the postal code can be replaced by just a city or town.
Click Address Lookup.
If necessary, refine the address:
Enter the street number or apartment number as requested and then click Refine Address.
Select the correct address:
Click the address.
Use the up and down arrows to highlight the correct address, then press the Spacebar.
Indicate whether the address is correct:
Click Yes to continue with the address.
Click No to return to the Address Lookup window. Return to Step 2.
Click Cancel to exit Address Lookup without selecting an address.
