Item Matrix Search
The Item Matrix can be used to find items by navigating through the merchandise hierarchy. Starting at the Department level, you can move to the lowest level of merchandise hierarchy and find a specific item. The merchandise hierarchy levels are color-coded to help you navigate through the different levels. When the item is located, it can be added to the sale transaction.
Item Matrix is configured off by default.
To find an item in the Item Matrix:
Click Find Item in the Register Sale screen (Figure 6-1).
Click Item Matrix.
The Item Matrix window opens at the highest merchandise level.
Click the next merchandise level in which the item is located.
Repeat Step 3 until the Item Matrix displays the correct item.
Click the item to add it to the transaction.
