Picking Up Local Inventory Order Items
...continued from Local Inventory Order Transactions step 3.
Find the Local Inventory Order for pick up by the customer:
If prompted, enter search criteria to find the Local Inventory Order.
If a customer has been associated with the transaction, Xstore POS returns a list of Local Inventory Orders for the customer.
Select a Local Inventory Order from the list. Only items that are in the state Ready to Pickup can be collected.
At the Local Inventory Order screen, select Pick Up Item.
If prompted, select Yes to pick up all the items. Selecting No returns to the Local Inventory Order screen.
This prompt only displays when there are multiple Local Inventory Order items.When the Scan Item Configuration is enabled, you are prompted to scan items at pick up to ensure they are the correct items being collected.
The system returns to the Local Inventory Order screen and all items are marked as Picked Up.
Select Amount Due to select a receipt method and to complete the transaction.
