4 Basic Transaction Entry
After logging in at the Home screen (See Login), the Start Sale option in the Main Menu provides you with the ability to perform sale transactions.
This chapter covers the following functions:
Start Transaction
To start a sale transaction:
Select Start Sale in the Main Menu to start a new transaction.
Entering Pre-Sale Information
Depending on your store configuration, pre-sale screens that display after login may include:
Selecting Commissioned Associates
If your store tracks the associates' sales for commissions and sales goals, you may be prompted to select a commissioned associate (or associates) to be linked to the items in a sale transaction. There are two ways to select a commissioned associate for a transaction:
Select the sale associate(s) for this transaction from the list by touching the name and select OK.
Alternatively, select the Select By ID option.
For each associate to add to the transaction:
Enter Associate ID. The ID of the logged-in user is the default value.
Select OK.
Figure 4-1 Associates by ID
When you are finished adding associates, leave the associate ID field blank.
Select OK.
Continue the transaction with:
<OR>
Entering Items
Use the options on the Register Sale menu to enter items, add discounts, modify the transaction, and to add gift registry items. Refer to Adding a Discount to a Transaction or Group of Items, E-mail Receipt Options, Modifying Line Items in a Sale, and Gift Registry for more information about these activities.
You may also be able to enter extended transactions such as:
To look up an item see Searching for Items.
Adding an Item
To add an item to a transaction from the sale screen:
Figure 4-2 Tablet Sale Screen - Scan Item Prompt
Scan an item barcode to add it to the transaction or enter an Item ID manually. Repeat as needed per item. As items are added, Xstore POS automatically applies any promotions and/or discounts that may be relevant to that item. It also shows the unit price, the extended price, and the tax that is relevant on that particular transaction item.
Figure 4-3 Tablet Sale Screen - Item Line
Figure 4-4 Handheld Sale Screen - Item Line
Performing a long press on the item line within a transaction, takes you to that item's product detail screen.
Quick Items Tab
The Quick Items tab contains items that are frequently purchased. This option found on Desktop, Tablet, and Thin Client devices allows you to add frequently purchased items more easily. You can select multiple items if required.
To add an item to the sale transaction by using the quick items tab, follow the steps below.
Select the Quick Items tab. Frequently purchased items are displayed.
Select an item to add to the transaction.
The item is displayed on the Sales Display Panel and on the customer display.
RFID
To support RFID (radio-frequency) scanning, Xstore POS can be integrated to the MagLinQ devices. These devices scan the EPC (Electronic Product Code), which includes scanning and retrieving both the product ID and RFID Reference Tag Number simultaneously.
Scan the RFID tag on the item.
Xstore POS reads the RFID Electronic Product Code (EPC) tag whilst the product barcode provides the product ID, and the RFID tag extracts the unique reference number of the product.
If the scanner is not working, manually enter the product ID.
Adding Non-Merchandise Items to the Sale
Non-merch items such as gift cards, gift card top-up, gift wrapping, cell phone recharge, can be added to the sale.
At the Sale screen, select Sell Non-Merch from the Sale menu to display the list of non-merchandise items available at the store.
Figure 4-5 List of Non-Merchandise Options
Because each Xstore POS menu is configurable, the non-merchandise items shown on your system may be different than the options shown in this guide. Depending upon your item choice, you may be prompted for additional information (such as a price).
Select an item from the list.
If prompted, select a non-merchandise item from the list to add the item to the sale.
Figure 4-6 List of Non-Merchandise Items
Depending upon your item choice, you may be prompted for additional information. If prompted, enter the information as required.
Figure 4-7 Prompt For Price
Xstore POS adds the non-merchandise item to the sale and the non-merchandise information is shown.
Item Restrictions
When certain items are selected, restrictions may apply. These include the following:
Customer Age Verification
allows you to configure customer age verifications to determine whether a customer meets the age requirements to buy certain items. You can set different age levels for verification (for example, 18 years and 21 years).
An additional age verification is only requested, if an item with a higher restriction is added to the transaction. For example, if the first purchased item has an age limit of 21 and the second item has an age limit of 18, there is only an age verification for the first item, but not for the second one.
To sell an item with an age verification, follow the steps below.
Enter an item where an age verification is necessary. Xstore POS Point of Service displays a prompt relating to the date of birth of the customer is before a specified date.
Select Yes to confirm the prompt. The item is shown on the Sales Display Panel. For additional items requiring an age verification 18 years, no prompt is displayed.
Select No. The item is not added to the Cart. If additional items with an age verification are entered, the prompt is shown again.
Cashier Age Restrictions
Xstore POS Point of Service allows you to configure cashier age restrictions to determine whether a cashier has the permission to sell certain items. You can activate/deactivate the cashier age restriction per store.
An additional age verification is only requested if an item with a higher restriction is added to the transaction. For example, if the first purchased item has an age limit of 18, there is only an age verification for the first item, but not for the second one.
If the cashier age restriction is activated and there is no date of birth entered for the cashier, the system displays the cashier age restriction prompt.
Enter an item with a cashier age restriction. Xstore POS displays a prompt requesting authorization of the transaction.
Figure 4-8 Cashier Age Restricted Item
Select Yes to authorize the transaction. If No is selected, the item is not added to the sale.
Figure 4-9 Cashier Age Restricted Item Override
Users holding the required security privileges must:
Enter their user name.
Enter their password.
The item is added to the sales transaction and shown on the Sales Display Panel.
Time Restrictions
allows you to configure a time frame in which certain items cannot be sold and/or returned, for example, alcohol. If this function is enabled, items with a restricted time frame can only be sold during authorized hours and days. You can activate/deactivate the time frame restriction by item, department and sub-department.
To sell an item with a time restriction, follow the steps below.
Enter an item with a restricted time frame.
validates the system time and day against the configured restricted time frame.
The system displays the prompt, that the item is currently restricted and not available for sale.
Press OK to close the prompt.
Other Prompts
Style Items
A style is an entry in the item database that has properties such as size, color, and width, and so on. Multiple regular items may be associated with a style ID. If you enter a Style ID, the system prompts for additional information.
Figure 4-10 Tablet Style Item
Select the dimension such as the color required.
Serial Numbers
If prompted for an item serial number:
Figure 4-11 Tablet Serial Number Prompt
Enter the item serial number and select OK.
To adjust an item, see Adjusting an Item.
When you are finished entering/adjusting items, tender the transaction. See Tendering the Transaction.
Adjusting an Item
To adjust an item that has been added to a transaction:
Figure 4-12 Tablet Sales Screen
Figure 4-13 Handheld Sale Screen
Select the item in the item list. A popup is displayed showing the item adjustment menu.
Figure 4-14 Tablet Item Adjustment Menu
Select the change to make to the item.
See Modifying a Transaction for information about the changes that can be made to an item.
To make another item adjustment, repeat these steps.
To add another item to the transaction, see Adding an Item.
Adding Item Coupons
To add a coupon to a transaction:
Figure 4-15 Handheld Register Options
Select Register Options in the Context Menu.
Figure 4-16 Handheld Add Coupon
Select Add Coupon in the Register Options Menu.
Figure 4-17 Tablet Coupon ID Prompt
Figure 4-18 Handheld Coupon ID Prompt
Scan the coupon or enter the ID of the coupon.
Select OK.
The coupon is applied to the transaction and Xstore POS returns to the item entry screen.
Redeeming a Rain Check
Rain Check is an optional feature that allows customers to purchase out of stock items for the same price later.
To redeem a rain check:
Figure 4-19 Handheld Redeem Rain Check
Select Redeem Rain Check in the Register Options menu.
Figure 4-20 Tablet Redeem Rain Check Prompt
Figure 4-21 Handheld Redeem Rain Check Prompt
Scan the rain check or enter the ID of the rain check.
Select OK.
The rain check is applied to the transaction and Xstore POS returns to the item entry screen.
If you sell non-merchandise items such as gift cards or services such as gift wrapping, or cell phone recharge, refer to Adding Non-Merchandise Items to the Sale for more information.
If you do not know the item number and cannot scan the item, use the Item Lookup option to find the item number. Refer to Searching for Items Using Item Lookup for more information.
If the item is not found in the current inventory at this store, use the Inventory Lookup option to locate the item at another location. Refer to Locating Items: Inventory Lookup for more information.
To add a discount, refer to Discount an Item for more information.
To change the tax (both item and transaction), refer to Changing Item Taxes more information.
If your system is configured to support awards and the customer's accumulated rewards can be applied to this transaction, select the Add Discount menu option.
The tendering process requires that you select or enter two basic items of information:
Form of payment (also called tender type-cash, check, credit card, gift card, foreign currency, and so on)
Amount paid with that tender type
Depending upon the form of payment and your store's policies, you may have to enter or select additional information, for example:
Credit card account number, CID number, and expiration date
Additional tender types if the first tender type did not pay the total due
Additional forms of customer ID (driver's license number, birth date, credit card number, or other ID)
Customer name
Customer address
Security approval for large sales or refunds
Refer to Processing Tenders for additional information about specific tenders.
Completing the Transaction
When you are ready to complete the transaction, you can touch the Amount Due button at the bottom of the screen or select the Add Tenders option to display a list of tender types. You can also swipe a credit card in a MSR or in a signature capture device.
If prompted to round up the amount for a charitable donation:
Figure 4-22 Round Up for Donation
Click No to continue with tendering without adding the amount.
Click Yes to add the charitable donation to the transaction, then continue with tendering.
The screen changes to the green phase to indicate tendering. The available tender types are shown.
At the tender list, touch the tender type.
Figure 4-23 Tablet List of Tender Types
Figure 4-24 Handheld List of Tender Types
At the tender amount prompt, enter the amount of the tender. Depending upon the tender type you selected, the tender amount prompt may default to the total amount due for the sale transaction.
Figure 4-25 Tablet Tender Cash Amount Prompt
Figure 4-26 Handheld Tender Cash Amount Prompt (Dark Mode)
Split Tenders: You may enter a partial amount if the purchase is paid with more than one tender type. After selecting a tender type, entering the amount and pressing OK, the system automatically prompts for the remaining balance due and you may select any of the valid tender types. See Splitting Tenders for more information.
<OR>
Select one of the Quick Cash buttons.
Figure 4-27 Handheld Quick Cash Buttons
Selecting a tender line brings up the Modify Tender menu where you can choose to void a tender, or to change a tender amount.
Figure 4-28 Handheld Modify Tender Menu
Figure 4-29 Handheld Sale Tender Options
Your system may print receipts without prompting you to confirm that the sale is complete. In that case, the system prints receipts as soon as the total of all tenders selected equals or exceeds the amount due.
If prompted, select to complete the transaction.
The system prints receipts as required. If you are utilizing shared printers, select a specific printer.
If your store issues e-mail receipts, additional/different prompts display. Refer to E-mail Receipt Options for more information about sending e-mail receipts.
See Printing a Gift Receipt for information about printing Gift Receipts.
Depending upon the configuration of your system, you may be prompted to scan a cash drawer. Scan the appropriate cash drawer for your system.
Note: If you are prompted that the cash drawer is unavailable, either wait for the cash drawer to become available, or scan a different cash drawer.
If required, provide change to the customer and close the cash drawer to complete the transaction.
Figure 4-30 Cash Drawer Change
On occasion, upon completing a transaction, a prompt may open asking whether to apply a system update.
If you agree to perform the system update, you will not be able to create any new transactions for a certain grace period. Existing transactions can be completed during the grace period.
Once the system is not in a transaction or if the required period has expired, the update will be automatically applied without asking the user. You cannot use the system during system updates.
Select No to be asked again after a period.
Select Yes to apply the update. A confirmation prompt opens:
Select Apply to perform the update.
Select Cancel to cancel the update and be asked to perform the update after a period.
Vertex Tax Engine
Overview
The optional integration of the Vertex Tax Engine with the Oracle Retail Xstore Point of Service system plays a crucial role in automating tax processes and significantly improving tax accuracy for businesses. With this, Xstore enables a more streamlined and efficient tax management experience.
Xstore facilitates the integration with the Vertex Tax Engine through two distinct methods:
Containerized Implementation: Businesses have the option to implement the Vertex Tax Engine as a containerized solution within the Xstore ecosystem. This means that the tax engine is encapsulated within a container, ensuring a standardized and isolated environment for tax calculations. This approach offers flexibility and scalability, allowing businesses to adapt the tax engine to their specific requirements.
Vertex Cloud Services Integration: Alternatively, Xstore also provides integration with the Vertex Cloud Services, which are directly offered by the Vertex Tax Engine. This approach allows businesses to leverage the cloud-based capabilities of the Vertex Tax Engine without the need to manage and maintain the tax engine infrastructure on-premises.
By providing these integration options and authentication methods, Xstore empowers businesses to optimize their tax processes, ensuring accuracy, compliance, and seamless handling of tax-related operations, whether through containerized implementation or cloud-based services offered by the Vertex Tax Engine.
E-mail receipts (e-receipts) save paper and time.
If your store issues e-mail receipts, you may be prompted for more information after the sale is tendered. Any receipts that have been set up for e-mail delivery are generated as PDF documents and sent to the customer's e-mail address as an e-mail attachment. This e-mail receipt process assumes the customer has an active e-mail address and has given permission to receive e-mail from the store.
After tendering the sale or return, you are prompted to select a receipt method, unless the customer has been set up to automatically receive e-mail receipts, in which case go directly to the next step.
Figure 4-31 POS Receipt Options
The choice you make here applies to all receipts. For example, if you choose to e-mail receipts, then all receipts such as Gift and Customer receipts are sent in an e-mail. You cannot print one but e-mail the other.
However, any receipt types that are not supported for distribution in an e-mail, per your store policy, automatically print on the receipt printer.
To print the receipt(s), select Print Only. All receipts are printed on the receipt printer and the transaction is complete.
To e-mail the receipt(s) to the customer, select Email and continue with step 2 below.
If you chose to e-mail the receipt(s), you are prompted for the customer's e-mail address:
If no customer is associated with the sale, enter the customer's e-mail address.
If a customer with an e-mail address on file is associated with the sale, verify the customer's e-mail address is correct as shown on the prompt. You can change the address if needed.
Select a receipt option:
Figure 4-32 POS Email Address Prompt
To e-mail the receipt(s) to this e-mail address, select Ok Email Only and the transaction is complete.
To both print the receipts and send an e-mail copy to this e-mail address, select Ok Print and Email and the transaction is complete.
If you decide not to send an e-mail receipt, select Cancel Email to return to the Sale Complete prompt (Figure 4-31) where you can choose to print the receipts.
The customer may have indicated that they wish to have e-mail receipts as their default. If this is the case, you will not be prompted for the customer's e-mail address.
E-mail addresses are validated for proper format. If the e-mail address does not have proper formatting, a warning message displays. Press Enter to acknowledge the message and return to the Email Address prompt where you can correct the error.
If you make any changes to a customer's e-mail address on file, you may be prompted whether the customer's profile should be updated with this new e-mail address:
Select No to send the receipt to the new address but keep the old address on file.
Select Yes to send the receipt to the new address and to also update the customer's profile with the new e-mail address.
If there are multiple receipts on the transaction, they are sent as multiple PDFs in one e-mail.
Receipts
This section describes the Receipt functions.
Multiple Printers
Stores that have multiple receipt printers can select a printer from a list of available printers or scan a QR Code and the receipt prints to that selected printer. If only one printer is available, the receipt prints directly to that printer and no selection is required.
Figure 4-33 Multiple Printer List
QR Code
In addition to selecting a printer from a list, you can scan a QR code placed on the front of an IP enabled receipt printer to select that printer.
Select Print or Print and Email receipt method to print a receipt.
From the list of printers displayed, select the barcode icon (shown on the top left of the Printer Selection list) to open the device camera.
Scan the QR code on the front of the printer.
When a QR code is valid and the receipt printer is configured, Xstore will send the data to the scanned printer. The printer list closes automatically.
When the QR code does not contain the information expected an 'Invalid Scan' message is shown.
When a QR code is scanned and Xstore finds it has valid information but is not part of the available printers, the message 'Receipt printer is not configured' is shown.
Retailers are responsible for creating QR codes for printers and placing them on the appropriate printers. They are also responsible for configuring available printers.
During a transaction, items may be selected for a gift receipt before a tender is selected, or between adding tenders. Gift receipts can also be issued immediately after a completed sale transaction, or from the Electronic Journal for eligible items in a transaction. Eligible items include regular sale items, special order pickup items, and layaway pickup items.
Select Gift Certificate Items in a Sale
While a sale transaction is being performed, you may use the following steps to select items to be issued gift certificates:
Figure 4-34 POS Gift Receipt Option
Figure 4-35 Handheld Gift Receipt Option
During a sale transaction, select Gift Receipt in the Context Menu. Xstore POS displays a list of items eligible for gift receipts.
Figure 4-36 POS Gift Receipt Items
Figure 4-37 Handheld Gift Receipt Items
Select Select All to print gift receipts for all items and select OK.
<OR>
Select the gift certificate items for which to print a gift receipt and select OK.
Click OK.
The gift certificate items are labeled in the View Port with a gift icon. Gift certificates will be printed at the end of the transaction.
At the end of the transaction, if you are prompted whether to group gift certificate items, see Group Gift Receipt Items.
At the end of the transaction, you may be prompted whether to print a gift certificate for each item:
Figure 4-38 Handheld Print Separate Gift Receipt Prompt
Click Yes to print a gift certificate for each item.
Click No to print one gift certificate for all items.
After tendering the sale, if there are multiple items that have been labeled as requiring a gift receipt, you may be prompted whether to group items on separate gift receipts. For example, you can group 2 items on one receipt, and 3 items on another receipt.
To group items on gift receipts:
Figure 4-39 POS Group Gift Receipts Prompt
Figure 4-40 Handheld Group Gift Receipts Prompt
If you are prompted whether to group gift receipts, select an option:
Click Yes to group gift receipt items. A gift receipt grouping window opens.
Click No to continue the transaction without creating gift receipt groups.
Select the items to group on one gift receipt.
Click Add Grouping.
The selected items are grouped into one gift receipt and removed from the list.
Repeat Steps 2 to 3 for each gift receipt group.
Click Finish and Print to print the gift receipts and complete the transaction.
Reprint Receipts and Documents
The reprint options provide a way to recover when there is a printer error or the printer jams. They allow you to reprint a receipt or a rebate offer for the customer.
Go to the login screen and select the Context Menu.
Figure 4-41 POS Context Menu
Select Receipt Reprint Options from the Context menu.
Figure 4-42 Reprint Options Context Menu
The following options are available:
Print a Rebate Receipt
Rebate receipts may be offered to customers so that they can retain the original receipt for a purchase, and mail in the rebate receipt as proof of purchase.
Select Rebate Receipt (See Figure 4-42). The system prompts for transaction information.
Figure 4-43 POS Transaction Lookup
Enter the transaction information by doing one of the following:
Scan the barcode on the original sale receipt.
Enter the barcode information and press Enter. The rebate receipt prints on the receipt printer.
The receipt is clearly labeled as a rebate authorization receipt.
This receipt cannot be used for merchandise returns.
Reissue a Gift Receipt
To create gift receipts for a previously completed transaction:
Select Reissue Gift Receipt (See Figure 4-42). The system prompts for transaction information.
Figure 4-44 POS Transaction Lookup
Scan the barcode on the original transaction receipt.
Xstore POS displays a list of items eligible for a gift receipt.
Select the gift receipt items using the appropriate procedure:
Xstore POS prints the receipt.
Reprint a Document
To reprint a document (such as a rebate offer):
Click Receipt Document. (See Figure 4-42).
The Reprint Document Lookup window opens.
Figure 4-45 POS Reprint Document Lookup
Figure 4-46 Handheld Reprint Document Lookup
Enter the search information for the document:
Series ID: Enter the ID for the document series.
Document Type: Select the type of document.
Vendor: Enter the name of the vendor who produced the document.
Click Process.
Xstore POS displays a list of documents matching the search criteria.
Figure 4-47 Handheld Receipt Reprint
Click the correct document.
Select Reprint Selected or Reprint All.
Xstore POS reprints the document on the report printer.
Reprint the Last Receipt
To reprint the last receipt created by the register:
Click Reprint Last Receipt (See Figure 4-42).
Xstore POS prompts whether to reprint the last receipt.
Click Yes to reprint the last receipt.
The receipt is clearly labeled as a reprinted receipt.
Offline Sales Transactions
If connection to all mobile servers is lost, it is possible to enter in basic sales and return transactions manually in Xstore POS, if your system is configured to do so.
Select Change Server from the Connectivity Problem screen.
Select Offline POS from the Change Server screen.
Figure 4-48 Offline POS Screen
See Offline Transactions for more information.
Entering an Offline Transaction
Select New Transaction from the Offline POS screen.
Figure 4-49 Offline New Transaction
Two options are available:
Add Item - goes to the manual sales transaction entry screen.
Add Return - goes to the manual return screen to prompt for receipt data. See Entering Returns when in Offline Mode for more information on return transactions.
Perform a Sales Transaction
To perform a sale in offline mode:
Select Add Item.
Change item price if needed.
Optionally, add a comment for the sale item.
Figure 4-50 Add Item Offline Sale Screen
Select OK.
Repeat the steps above as needed to add each item.
Figure 4-51 New Offline Sale Transaction
When done, select Add Tender.
Select a tender type from the dropdown list. Not all tender types are available.
Optionally, add a comment for the tender.
Figure 4-52 Add Tender
Select OK when done.
Figure 4-53 Complete Transaction
Select Complete Transaction and enter an email address for the receipt.
Optionally, enter a comment.
Figure 4-54 Populated Complete Transaction Screen
Select Show Receipt.
Figure 4-55 Show Receipt Prompt
Select OK. The UUID QR code is printed.
Figure 4-56 Sales Receipt QR Code
Ask the customer to take a picture of the code with their mobile phone or to write down the receipt code.
Figure 4-57 Completed Offline Transaction
This UUID QR code can be used for returning the items or to get a transaction receipt when the store is back online. See Printing a Transaction Receipt for more information.
At the end of each transaction the system checks to determine if the mobile server is back online:
If the mobile server the device was configured to use is back online, then the device returns to the Xstore POS login screen.
If another server in the list is online, you are taken to the Change Server configuration screen. The offline mode will then be disabled. See Offline Transactions for more information.
If no servers are available, you go to the list of offline transactions and can choose to conduct another one or return to the Change Server screen.
See Reviewing Offline Transactions when the mobile server is back online to approve or reject the transactions performed whilst offline.
All offline transactions need approving/rejecting before store close.
