36 Omnichannel Order Maintenance
Oracle Retail Order Orchestration Cloud Service is an optional module that can be interfaced with Xstore to provide information about inventory availability across all sales channels. Using the functionality described in Order Transactions Through Order Orchestration Cloud Service, you can sell an item that is not in stock at your store and the Order Orchestration Cloud Service module automatically selects the best location to fulfil the customer's order across the enterprise. After any Omnichannel order is placed, the Order Maintenance feature set offers the ability to view and action orders assigned to the store for fulfillment or retrieval by the customer.
Unfulfillable Order Status
Figure 36-1 Orders
Order Lookup
After Order Broker is configured for your store, use the Order options to maintain the order. A store can only see orders initiated in the store and orders downloaded to the store for sourcing or pick up.
If your store has been assigned as the source to fulfil an Order Broker order, you need, to ship the items to the customer. If the Order Broker order was created in your store, you can use these options to track the progress of the order as it is processed.
To maintain/view an order:
Select Orders from Global Navigation.
Select the Order Maintenance option from the Orders menu.
Figure 36-2 Order Search Form
At the Order Search form, enter the search criteria needed to find an order:
To find all pending orders for fulfilment, select the Open Order Status value as the search criterion.
Order ID: The order identifier number.
Last Name: The customer's last name.
First Name: The customer's first name.
Phone: The customer's phone number.
Order Type: The type of order.
Order Date: The date the order was set up.
Status: See Order Status.
Shipping Method: The shipping method for the order.
Failed to Pickup: Select Yes to search for orders that have not been collected within a certain time from when the order was ready for pick up.
At the Order Search results list, select an order.
Figure 36-3 Order Search Return List
The system displays the Order maintenance screen. See View Order for details.
View Order
Selecting an order from the Search List displays the Order Dashboard.
Figure 36-4 View Order
The following information is displayed on this screen:
Table 36-1 Order Dashboard
| Component | Description |
Top Area |
Contains the type of Order Number, Order Type, Order Status, Date, Order Age, Origin and Reference Number. This area also displays a drop down menu with the Order Options. The order number is the number provided by the system that requested/originated the order. The reference number is an optional value that identifies the order. The status displays next to the Order Number. The area displays the following information:
Left Panel |
Right Panel |
Order Totals
Figure 36-5 Order Options Menu
Select an option from the Order Options menu to process the order: Accept Order, Reject OrderPick/Reserve Order, Un-reserve Order, Check Inventory, Ship Order, Cancel Order, Package Collection or Unpack Order..
Accept Order
To Accept an order or specific items on an order:
At the Order Maintenance screen, select the specific items or for the entire order, select the Accept Order menu option.
Figure 36-6 Accept Order Prompt
At the confirmation prompt, select Yes to accept the order.
At the Order Accepted prompt, select OK to continue.
Reject Order
When you reject an order or specific item in the order, it changes the order status to open sends it back to the Order Broker where another source/fulfilment location is determined.
At the Order Maintenance screen, select specific items or for the entire order, select Reject Order.
At the Reject Order confirmation prompt, select Yes to reject the order.
Figure 36-7 Reject Order Confirmation Prompt
If prompted, select a reject reason code.
Pick/Reserve Order
After accepting an order, the items need to be retrieved and put aside. When picking/reserving items for an order, the screens shown are dependent on your store’s configuration.
To display a scannable pick list rather than printing a paper pick slip, Enable Pick Slip Scanning must be enabled, and the Scan Pick List Items option is shown at the bottom of the Order Worklist screen. Continue with Scan Pick Slip Items.
If the Enable Pick Slip Scanning setting is not enabled, the pick slip is printable from the Order Worklist screen or automatically printed when the order is accepted. Continue with Picking/Reserving an Order.
Using the virtual pick list, items to pick are scanned from a list on a mobile device. If needed, the items can be entered manually if the barcode is unreadable. Scanning items ensures the items being set aside, for order fulfilment, are the exact items required. This functionality replaces the printed pick list from automatically printing upon Order Acceptance. The option to print a pick list is still available if desired by selecting the Print Pick List option from the Order Worklist.
At the Order Worklist, select the order and select Scan Pick List Items.
Figure 36-8 Order Worklist with Scan Pick List Items Enabled
If your store is configured to disallow the splitting of an order line where there are multiple quantities into multiple order lines, a warning message that their store does not allow fulfilment of partial line orders. Confirm you have the quantities required for line items before scanning.
On the mobile device scan each item as it is picked. As items are scanned, the Quantity of that item goes down.
Continue scanning each item until all items have been scanned. When the required quantity of the item has been scanned, the item is removed from the list.
If the item does not scan, select Manual Entry and enter the ID of the item.
If an item is scanned or entered that does not belong to an order, a warning message is shown. Select OK to continue.
Print Pick List
The pick slip is printable from the Order Worklist screen (see Figure 36-8) or automatically printed when the order is accepted.
Figure 36-9 Pick Slip
To Pick/Reserve items on an order:
At the Order Worklist screen, select the order to pick/reserve.
At the Order Maintenance screen, select the specific items or for the entire order, select Pick/Reserve Order. If you cannot fulfil the order for some reason, you can reject the order at this point. See Reject Order for more information about rejecting an order.
The Pick/Reserve Order menu option is only available after you accept the order.
If your system has the Scan Items Prior to Adding to Transaction setting configured, the items display in a list to scan from to confirm they are the correct items.
If your system does not have the Scan Items Prior to Adding to Transaction setting configured, collect the items and continue at step 5.
Scan the items from the list. The items will be marked Reserved and can be shipped or ready for customer pickup.
After all items for the order have been scanned or manually entered, select OK at the prompt.
For Delivery type orders, use the Ship Order function to complete the order delivery process. See Ship an Order.
For other Order types, the Order status is updated to Ready for Pickup.
Un-reserve Order
To un-reserve an order:
Since the order has been accepted it will no longer appear in the Order Worklist. From the Main menu, select Customer - Order Options - Order Maintenance.
Enter the search criteria and select Search.
If more than one order is returned, select the order you wish to modify.
Select Un-reserve Order.
Select Yes to confirm.
The order status changes to Open, and the Item Status changes to Accepted.
Cancel Order
Orders that customers have failed to pickup can be cancelled at a store if no deposit or money has been taken and the items returned to on-hand inventory for that store.
Orders that have had a deposit taken, associates should contact the customer to remind them to collect the order or to refund/cancel it in the Register mode.
To cancel an omnichannel order that has not been collected:
Open an existing order, see Order Maintenance.
Click Cancel Order from the Context Menu.
Confirm you want to cancel the order:
Click No to return to the order without canceling it. Click Yes to cancel the order.
Select a reason code to cancel the order.
The Order Status is updated to Cancelled and the on-hand inventory automatically adjusted.
Check Inventory
To verify you have enough stock on hand to fulfil an order, select the Check Inventory menu option. The Order Inventory Levels form shows the item quantity ordered and the current quantity on hand.
Figure 36-10 Order Inventory Levels Form
Ship an Order
For Delivery type orders, select the Ship Order menu option to ship the items. Xstore POS creates the Shipping Document for this order. This option is only available at the order sourcing location when the status of the items on the order is Reserved.
At the Order Maintenance screen, select Ship Order from the Context Menu.
When prompted, select Yes to confirm you want to ship the order.
When prompted, select Yes to print a shipping label.
If prompted, enter the total weight for the shipment and select Process.
When prompted whether to accept the shipping method chosen when the order was set up, perform one of the following steps:
To accept the shipping method selected during order setup, select OK and go to step 6.
To change the shipping method selected during order setup, select Override Shipping Method, select a shipping method from the list.
Figure 36-11 Select Shipping Method
The Override Shipping Method option is controlled by security.
You are prompted for Manager override if you do not have the required level of security to perform this function as indicated by the Security Override icon shown here.
Figure 36-12 Print Label Prompt
Print the shipping label. If the shipping carrier's label cannot be printed for any reason, you can print a label manually by following the prompts for label location selection and printing.
Figure 36-13 Tracking Number Prompt
If prompted, enter the tracking number for the shipment and select Process.
Figure 36-14 Packing Slip Prompt
If prompted, to print a packing slip for the shipment, select Yes to print the packing slip.
Xstore POS returns to the Order maintenance screen. The status for each item is updated to either In Transit if the order is being shipped to another store or Fulfiled if the order is being shipped directly to the customer.
Allocating an Item
If you do not use the Xstore POS Receiving module to receive items, select the Allocate Items menu option at the Order maintenance screen to automatically mark the item as received and ready for pickup. This allocation process performs all the Order Broker updates, local status updates, and customer e-mailing rules typically performed by the Xstore POS receiving module and moves ON_HAND inventory to the ORDER bucket for allocation purposes.
The Allocate Items menu option is only available when the following conditions are true:
Your system is not set up to auto-generate receiving documents
The order type is either Transfer Pickup or Web Pickup
This is the store where the order is to be picked up
The items on the order have a status of In Transit
To allocate items, select the Allocate Items menu option at the Order maintenance screen.
When prompted, select Yes to confirm you want to receive the item(s). The system updates the item status to Received and the order status is updated to Ready for Pick Up.
Order Worklist
The Order Worklist shows orders that require action: either fulfillment, or rejection if you cannot fulfil the request.
Select the Order Worklist option from the Order Options menu to display a list of orders to be fulfilled by this store.
The orders shown in the Order Worklist are the orders that require action: either fulfilment, or rejection if you cannot fulfil the request.
Depending on your store configuration (set in SystemConfig.xml), delivery orders may be listed before customer pickup orders.
Figure 36-16 Order Worklist
The following Order Worklist actions are available:
Print Order Pick List
Select the Header Overflow Menu and then select Print Order Pick List.
Figure 36-17 Print Order Pick List
Select Yes to print an Order Pick List for all Accepted Orders.
Select No to return to the Order Worklist.
Accept All Orders
Select Accept All Orders.
Figure 36-18 Accept All Orders
Select Yes to mark all Polled orders as Accepted.
Sort Orders by Order Type, Status, and Shipping Method
You may also select an order from the Order Worklist and then perform the following actions by selecting the Header Overflow Menu:
Accept Order
The Action column may indicate "Under Review." When the order is under review, you cannot accept or reject items. The customer can, however, cancel the order.
If you select Accept All Orders a prompt displays indicating orders under review will not be changed.
Orders that are still pending beyond a specified age threshold are shown in red text in the list. In the example shown above, any orders that have been pending for 4 days or more are flagged.
