56 Till Options
Till Option functions are primarily related to the movement of money into and out of a till (a cash drawer). Till options include No Sale, and Post Void. Additional options such as Change Float, Paid In and Paid Out transactions and Tender Exchange are available on the Mobile POS.
This section describes the available till options:
Change Float: Select this option to change the amount of cash that remains in each till after the end count is performed. See Changing the Float Amount.
Foreign Currency Maint: Select this option to update the exchange rate between the local currency and foreign currencies that are acceptable tenders. See Foreign Currency Maintenance.
No Sale: Select this option to perform a no sale transaction to open the cash drawer. See No Sale.
Paid In: Select this option to perform a paid in transaction. This option requires an attached till. See Performing Paid In/Paid Out Transactions.
Paid Out: Select this option to perform a paid out transaction. This option requires an attached till. See Performing Paid In/Paid Out Transactions.
Post Void: Select this option to perform a post void transaction. See Post Voiding Transactions.
Tender Exchange: Select this option to perform a tender exchange transaction, which allows you to exchange one form of tender for another. For example, accept a customer's check for some amount and give them the same amount as cash. See Tender Exchange.
The Float is the total value of cash counted and removed from the till, but not included in the bank deposit. This cash remains in circulation to be used the next time the till is opened. This option can be used whenever you need to change the amount withheld from the bank deposit and can be adjusted per till. For example, you may want to change the float amount during the December holiday shopping season to plan for increased sale activity.
Select the Global Navigation menu and then select, Till.
Select Till Options.
Select Change Float.
The system prompts for the reason you are changing the float amount. Select a reason from the list.
Figure 56-1 Change Float Reason List
Depending upon the reason you selected, you may be prompted for additional information/comments. If prompted, enter the information as required and select OK.
If your store is configured for foreign cash currency tenders to be given as change, select the type of float tender from the list.
Figure 56-2 Change Float - Currency List
The system displays a list of tills. Select the till(s) you want to change. After you select all the tills you want to change, select OK.
Figure 56-3 Change Float Till List
The system prompts for the new float amount for the selected tills. Enter the new float amount for the tills in the list and select OK.
Figure 56-4 New Float Amount Prompt
The system prompts to confirm the new float amount for the selected tills. Select Yes to accept the new float amount. The system updates the float amount to the new value for the selected tills and returns to Global Navigation.
Figure 56-5 Confirm New Float Amount Prompt
You can edit the currency exchange rate for the foreign currencies that are accepted as tenders for sale transactions, if your store policy allows it. Some currency rates fluctuate frequently, so you can edit the exchange rate as often as necessary.
Select Foreign Currency Maint..
Oracle Retail Xstore POS displays a list of foreign currencies. Select the currency whose exchange rate you are changing.
Figure 56-6 Foreign Currency List
The system displays the current information for the currency you selected. Enter the new exchange rate and a comment, then select Save New Rate.
Figure 56-7 New Exchange Rate
Oracle Retail Xstore POS prompts whether to change the exchange rate. Select Yes to continue.
Figure 56-8 Confirmation Prompt
The new currency exchange rate is now effective. Oracle Retail Xstore POS returns to the Main Menu.
About exchange rate calculations in currency conversions:
The exchange rate with the base currency ID of the local currency ID is the value that is used to calculate a converted currency amount. The exchange rate is stored as a factor of the local exchange rate.
The conversion is calculated by multiplying the local currency by the exchange rate.
No Sale
Use the No Sale option to open the cash drawer for a reason other than a normal sale transaction.
Select No Sale.
The system prompts you to select the reason you are opening the cash drawer. Select a reason from the list.
When configured, scan the cash drawer on which to perform the no sale.
The system may prompt you to enter a comment about the reason for opening the cash drawer. If it is required, enter the pertinent information in the comment entry form and select OK.
The system prints a No Sale receipt for your records.
A Paid In transaction allows you to move funds into a till from non-sale sources such as returned check charges, found money, and change from a Paid Out transaction.
A Paid Out transaction moves funds out of a till for non-refund purposes such as business expenses and office supply purchases.
Store policy controls the list of valid reasons that you can select for performing a Paid In or Paid Out transaction. In addition, store policy controls whether receipts are produced by these two transactions.
The Paid In and Paid Out transactions may also be available on the Till Options Menu at the register.
A till must be attached to the register to perform Paid In/Paid Out transactions. If a till is not attached and one of those options is selected, a message is displayed indicating that a till must be attached for the transaction to be performed.
In an only networked cash drawer environment, you are required to scan the cash drawer barcode to link it to the transaction before the drawer pops.
In a mixed network/local cash drawer environment, select whether to use a network cash drawer.
Paid In Transaction
Select Paid In.
If the register has more than one cash drawer, you may be prompted to select the till to be used for this process.
The system prompts you to enter a paid out receipt barcode. If you are now placing funds back into the till from a previous paid out transaction and you have the receipt, scan or enter the barcode and select OK. Otherwise, select OK to bypass this prompt.
Figure 56-9 Paid Out Receipt Barcode Prompt
Select a reason for this Paid In transaction and select OK.
Figure 56-10 List of Paid In Reasons
There may be additional prompts for information (such as a comment) depending upon the specific reason code that you select.
At the Amount prompt, enter the cash amount you are adding to the till and select Return.
Figure 56-11 Enter Amount Prompt
Oracle Retail Xstore POS prompts you to close the cash drawer (if configured to do so), prints a receipt, and returns to the Main Menu.
Note the reference to the original paid out transaction number shown in this example. This information associates the original paid out transaction with the current paid in transaction for accounting purposes.
Select Paid Out.
Select a reason for this Paid Out transaction and select OK.
Figure 56-12 List of Paid Out Reasons
At the Amount prompt, enter the cash amount you are removing from the till and select Return.
Figure 56-13 Enter Amount Prompt
Performing a Post Void transaction, changes the status of a sales transaction to Void. Only transactions for the current business date can be post voided.
All records in the system are reset, almost as if they had never occurred during the original transaction, and the transaction record is retained in a voided state.
Certain kinds of sale transactions may involve extended transactions — activities related to the transaction that occur outside of the system. For example, special orders, work orders, and layaways are extended transactions.
Although the system checks for such conditions when a post void is executed, some aspects of the transaction may need to be reversed by an additional transaction such as a return. If the system detects an extended transaction, a prompt to continue or discontinue the post void process displays.
The types of transactions that may be post voided are determined by the home office.
If you scan or enter a barcode for a transaction type that cannot be post voided (such as a timecard transaction), the system displays a message indicating that the transaction type cannot be post voided. Select OK to acknowledge the message and the system returns to the Till menu.
You can post void transactions from the register from the Electric Journal (see Post Voiding a Transaction), or from the Till menu.
Select Post Void.
A till must be attached to the register to perform a transaction void. If a till is not attached, this option may be grayed out on the menu (Register Accountability mode), or a message may be displayed if the Post Void menu option is selected (Till Accountability mode). If the register has more than one cash drawer, you may be prompted to select the till to be used for this process.
At the Post Void prompt, scan or enter the transaction information and select Search to continue.
Figure 56-14 Post Void Prompt
Oracle Retail Xstore POS prompts: Are you sure you want to post void the selected transaction? Select Yes to continue with the post void transaction.
The system prompts for the reason you are performing the post void. Select a reason from the list and select OK.
The system may prompt for a comment about the post void. If prompted, type a comment and select OK to continue.
Oracle Retail Xstore POS post voids the transaction, prints receipts, and returns to the Main Menu.
Tender Exchange
The Tender Exchange function permits an associate to exchange one form of tender for another. The types of tenders that may be exchanged and the threshold exchange amounts are determined by your store policy.
To perform a Tender Exchange:
Select Tender Exchange. A Tender Exchange Incoming Tender window opens listing the tenders available such as Check, Gift Card, Mall Certificate, and Foreign Currency.
Select the incoming tender type from the tender exchange list.
If a check tender was selected in Step 3, enter information about the check:
Figure 56-15 Check Tender
Enter the check MICR number, then select the Return key.
Enter the Check number, then select the Return key.
Enter the state or province that issued the ID being used to verify the customer's identity, then select OK.
Enter the ID number, then select OK.
Enter the birthdate on the ID, then select OK.
Enter the amount of the incoming tender.
Figure 56-16 Tender Amount
If necessary, select whether to add another incoming tender to the exchange:
Select Yes to add another tender. Return to Step 3.
Select No to continue with the current tenders.
A Tender Exchange Outgoing Tender window opens. Continue with Step 7.
Select the outgoing tender.
Select OK. Xstore prompts for the amount of the outgoing tender.
The default value is equal to the maximum amount that can be redeemed in the selected tender.
If necessary, change the amount to return to the customer. select Enter.
If necessary, scan the cash drawer with which to perform the tender exchange.
If the entered outgoing amount was less than the maximum, a Tender Exchange Outgoing Tender window opens. Return to Step 7.
If the outgoing amount was the maximum amount, Xstore prompts whether the tender exchange is complete. Continue with Step 12.
Indicate whether the tender exchange is complete:
Select Yes to complete the transaction.
Receipts will print.
Select No, and a Tender Exchange Incoming Tender window opens. Return to Step 3.
