Deployed Versions
Use Deployed Versions to view the number of stores, and the version numbers deployed to those stores, in a pie chart format. This version information is reported to Oracle Retail Xstore Office by the primary register at the store.
From the Oracle Retail Xstore Office menu, select Config Manager - Configurator, or click the Configurator link in the Configuration Manager panel.
Select the configuration scope for the deployment. The process varies with the scope selected on the Configuration Scope Options page (Figure 5-36):
Global Configurations - continue with step 3 below.
Configuration Overrides:
Select a Profile Group from the list.
Select an Element from the list.
Click Next.
Continue with step 3 below.
Store Specific Overrides:
Type the store number or begin typing a store number or name in the Store # field.
Select the store from the store list.
Click Next.
At the Configuration Scope Actions page, select Deploy.
Figure 5-73 Configuration Scope Actions Page - Global Example
At the Schedule Deployment Page, select Deployed Versions:
Figure 5-74 Schedule Deployment Page - Global Scope Example
With the pie chart displayed, click on a section to display a list of the stores to which the version number was deployed.
The pie chart represents the number of stores, and the version numbers deployed to those stores, based on the version reported from the primary register in the store.
The list includes the Store Name, Store ID, Phone Number, and Address.
