Deployment History
Use Deployment History to view a summary of current configuration deployments for the profile element and organization node.
From the Oracle Retail Xstore Office menu, select Config Manager - Configurator, or click the Configurator link in the Configuration Manager panel.
Select the configuration scope for the deployment. The process varies with the scope selected on the Configuration Scope Options page (Figure 5-36):
Global Configurations - continue with step 3 below.
Configuration Overrides:
Select a Profile Group from the list.
Select an Element from the list.
Click Next.
Continue with step 3 below.
Store Specific Overrides:
Type the store number or begin typing a store number or name in the Store # field.
Select the store from the store list.
Click Next.
At the Configuration Scope Actions page, select Deploy.
Figure 5-70 Configuration Scope Actions Page - Global Example
At the Schedule Deployment Page, select Deployment History:
Figure 5-71 Schedule Deployment Page - Global Scope Example
The Deployment History search results list shows the other configurator deployments of the same Org Node/Element, along with the status for each.
Figure 5-72 Deployment History Search Results List
Select a deployment to view additional detail. If needed, a deployment can be edited. See Deployment Management, section Viewing Deployments for more information about Deployment History and editing deployments.
